Swordfish data logger viewing?
  • kacordy
    • Oct 2012
    • 484
    I'm at a loss. Are there instructions somewhere? Does the ESC need a battery plugged in? Program does not open? First SF. First attempt to view data.
    Thanks, Allen
  • kevinpratt823
    • Aug 2012
    • 1462
    ESC need power. Hook the link up, open the page, power the ESC, then click open device. You may have to change the com port, I forget how to figure out which one you want. Try this and let us know if you get it.
    My private off road rc track
    • kacordy
      • Oct 2012
      • 484
      Kevin, I will try with a battery.
      Thanks for the guidance, Allen
      • kacordy
        • Oct 2012
        • 484
        I do not understand. When I click on device, bottom left, It gives me invalid port number. I've tried both ports. Link is red. Battery plugged in.
        Allen
        • kacordy
          • Oct 2012
          • 484
          Very strange program. Is the red light supposed to go off on the link? Green light correct next to open device? But it tells me device is not open?
          • kevinpratt823
            • Aug 2012
            • 1462
            There are a lot of threads on various forums discussing the little technical things you have to do, this one has a link to the manual, I'm sure it's somewhere on the hifei site too but....https://astecmodels.co.uk/pdfs/hifei...%20Manuals.pdf
            It has screenshots, but it says---www.hifei.com Swordfi
            sh ESC MANUALS 7 page/ 12 pages
            Please refer to the labe
            l of USB Linker and correctly connect the
            receiver lead of ESC to USB Linker.
            Connect the USB Linker to one of the ava
            ilable USB ports of PC. A little
            red LED on USB Linker will
            light up. The green LED on the controller would light
            up while connecting is su
            ccessful otherwise not.
            When successfully connect to PC, th
            e computer will automatically r
            ecognize a ‘com port’ as the name
            “CP210
            USB to UART Bridge Controller” ,
            please find the correct ‘com por
            t’ number on you PC in this
            way.
            The com port is generally ‘com 3’ or ‘com 4,’ but there are
            different ‘com port’ on different computers. You can find the
            accurate com port on your computer in this way:
            Click the right button of mo
            use the icon ‘My Computer
            ’→Manage →
            Device Manager →Ports(Com & LPT).
            The‘com port’after
            “CP210
            is the right one.
            • kacordy
              • Oct 2012
              • 484
              Kevin, Thank You so much for this detail. I got frustrated so I will try again in the morning. Time for some Blanton's bourbon and UFC 179, lol
              Allen
              • Bryan73
                • Mar 2012
                • 22
                Allen
                Did you install the driver, especially if you are running a 64bit operating system?
                Just in case you have not, go to your program directory.
                Unless you have a different main drive it should be:
                C:\Program Files(x86)\HiFei V.4.12 (or 4.11 if you have that one)
                Look for this file - CP210xVCPInstaller_x64.exe (64bit version) and run it if you have a 64bit O/S.
                there is also CP210xVCPInstaller_x86.exe (32bit version)
                Upon installing that driver, somewhere along the way (if you pay attention) it will let you know which comm port it's using. If not, go to device manager, under ports and it will show you. Just look for this device: Silicon Labs CP210x USB to UART Bridge.
                Now just plug your ESC into USB device then plug USB device into to your PC, battery is needed ONLY for those ESCs which do NOT have a built in BEC
                • Kvance
                  • May 2014
                  • 9
                  If you continue to have problems you can email me at Kentvance4135@Gmail.com and I will give you my phone # and I can tell you easier than I can type how to get it to work . I had problems also with a swordfish 220 pro plus just a few months ago.
                  • rickwess
                    • Apr 2013
                    • 777
                    You definitely don't need a battery connected to the ESC to program it or read the logs.
