Hifei frustration
  • kevinpratt823
    • Aug 2012
    • 1462
    Hifei frustration
    I can make my way through a computer, but like many of us I am no expert, so why does it seem that Hifei software/firmware is such a complicated PITA to deal with from their site? I cannot get the V4.11 software to set up and run, not sure what hoops I need to jump through there.......They told me to open it with google chrome, and save it on a drive other than "C"......I'll have to search the threads cause I know I've seen others scratching thier heads there.......
    Then I just "upgraded" my 240pro+hv via the site, now it cuts out after 2 seconds, even out of the water with no load! Tried going back to the previous software, nope....tried other batts, rx batt, lvc settings.....nothing gets it back working.
    My private off road rc track
    This was what I had to go thru, the link:http://forums.offshoreelectrics.com/...-Swordfish-esc
    It may or may not apply to your situation but will save you a bit of time searching.
    Good luck.
    • kevinpratt823
      • Aug 2012
      • 1462
      Thanks Tlandauer, I had already been reading that, and had actually sent Alexgar a message. In the meantime, I actually managed to get it to work! With a little research, I downloaded a free RAR file opening program herehttp://download.cnet.com/WinRAR-32-b...-10007677.html Apparently it's similar to a zip file, but I had no program to deal with it. Opened it and saved it, worked like a charm! I also opened up the firmware for the esc, and realized I was previously trying to use the older firmware, likely causing my problem. My ESC is a Pro+ II, didn't realize the firmware changed with the new design that has the extra set of cooling tubes, in short, the boat appears to be working fine now as well.
        Glad to know everything is working out for you!
        Happy Boating !
