swordfish 200a esc parameters HELP!
  • out of stock
    • Jan 2014
    • 123
    people i need help programming my esc.
    its a swordfish 200a opto
    my setup:
    -leopard 1730kv D
    -sf 200a esc
    -running on 6s (2 6s packs in parallel)
    -x447 prop
    here are my parameters
    LVC:
    *AUTO
    *5.0V
    *2 CELLS
    *7.2V
    *8.4V
    *3 CELLS
    *4 CELLS
    *5 CELLS
    *6 CELLS
    all the way to 20 cells
    LVC PER CELL:
    *3.0V
    *3.1V
    *3.2V
    *3.3V
    *2.5V
    *2.6V
    *2.7V
    *2.8V
    *2.9V
    BRAKE TYPE:
    *NO
    *SOFT
    *HARD
    *NO
    TIMING:
    *AUTO
    *0 DEGREE
    *2 DEGREE
    *4 DEGREE
    *6 DEGREE
    *8 DEGREE
    *10 DEGREE
    *12 DEGREE
    *14 DEGREE
    *16 DEGREE
    *18 DEGREE
    *20 DEGREE
    *22 DEGREE
    *24 DEGREE
    *26 DEGREE
    *28 DEGREE
    *30 DEGREE
    *LOW
    CUTOFF TYPE:
    *HARD
    *SOFT
    START TYPE:
    *STANDARD
    *FAST
    *SOFT
    PWM:
    *8KHZ
    *12KHz
    *16KHZ
    PLEASE HELP A BROTHER OUT!!
  • Rocstar
    Joel Mertz
    • 1536
    my setup:
    -leopard 1730kv D
    -sf 200a esc
    -x447 prop
    I would suggest starting with a smaller prop. What size motor and what hull?
    LVC:
    *6 CELLS
    LVC PER CELL:
    *3.5V
    You may have to lower this if the ESC cuts out with a full charge, and time your runs.
    BRAKE TYPE:
    *NO
    TIMING:
    *2 DEGREE
    CUTOFF TYPE:
    *SOFT
    START TYPE:
    *SOFT
    PWM:
    *8KHZ
    • out of stock
      • Jan 2014
      • 123
      outstanding man thanks. im starting with a 445
      cf cheetah 4092
