Swordfish 300 and 120
  • Gary
    • Jan 2009
    • 1104
    OK since Castle is done I had to find a new ESC and picked the 120amp for my little Miss Budweiser and the 300amp unit for my PT45. Both are holding back power and I have gone through the programs many many times with the esc, transmitter and receivers. The Miss Bud will run at 75% power but works perfect other than that and the 300amp version in the PT is off by 10mph and 2,000 rpm . Anyone run into this? Can a controller be not as "powerful" from one brand to another?
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
  • cacofonix
    • 243
    hello Gary
    this problem is "normaly" solved with the latest firmware you can download on Hifei web site
    i had same behaviour .............. 8 month ago, new firmware solved this
    problem occur only with Spektrum radio
    one solution is to set throttle to 80% , then calibrate radio and Esc
    when done, set throttle to 100%
