software upload for swordfish 300 esc
  • Gary
    • Jan 2009
    • 1104
    I am having a problem uploading the Swordfish 300 amp esc disc to my computers. I have four in the house and they all say I need a 64 bit of DP inst.exe. Any ideas? My sons computer will see the disc and show the manuel {directions} but will not load the program part.My other computers will not even show there is a disc in it. Any ideas? I do have windows 7 as well.Thanks.
    H&M 1/8 Miss Bud 73 mph
    Chris Craft 16 mph
  • oscarel
    • Dec 2009
    • 2373
    Try this http://www.hifei.com/#!download/cgpq
    • photohoward1
      • 1781
      Load to any drive but the c:/ drive
      • klauskra
        • Jan 2012
        • 9
        Hi
        Got the same problem, 64 bit software of win 7, doesn´t take this version of hifei swordfish...
        Tried even the link above, but its the same version like that on cd.
        Gonna contact the seller.
        • Mad Racer
          • Nov 2013
          • 140
          Yep I have the same problem with my PC running Widows 7.
          In the instructions it states do not load to C drive if you have Windows 7. So what do you do then??? C drive is your hard drive. I see. it is installed but nothing happens
          Amazing!
          • klauskra
            • Jan 2012
            • 9
            Gonna try on the old PC...
            • klauskra
              • Jan 2012
              • 9
              i got harddrive split into "C" and "D", perhaps I can install on "D"
              • klauskra
                • Jan 2012
                • 9
                ok, on old pc, the software is installed, but do not have the boat with esc at home today, is to a friend. he made mods on it. I`ll write tomorrow.
                • rickwess
                  • Apr 2013
                  • 777
                  It's not that you can't install on your C drive, just don't install it in the default "Programs (x86)" folder. Install it most anywhere else, say in your RC Boat folder. You will still get the "64 bit of DP inst.exe" message so once the install is complete go into the "HiFei v4.x" and run the application "CP210xVCPInstaller_x64".
                  • Gary
                    • Jan 2009
                    • 1104
                    Well I gave up and bought the program card. It will only show peak values but I will live with it.
                    Chris Craft 16 mph
                    • drwayne
                      • 3012
                      buy yourselves a 4Gb USB drive .. once plugged in it has it's own drive letter assigned ..
                      install the software there....
                      btw .. USB2.0 drives are native at 32bit
                      • Gary
                        • Jan 2009
                        • 1104
                        Got it all working but do not like this controller at all. Motor sounds very strained when first hiting the throttle, power is down across the board, shows spikes of 508 amps when normally around 350-375,according to castle readings, no reverse which is a real pain sometimes trying to line her up and overall a quirky unit. My Caste 240 units where Sooo much smother, easyer to work with and overall just better. If they only could handle more power when castle came out with them. Oh well.
                        Chris Craft 16 mph
                        • oscarel
                          • Dec 2009
                          • 2373
                          Sent from my SAMSUNG-SGH-I747 using Tapatalk
                          • drwayne
                            • 3012
                            castle were so well received and popular they stopped production.
                            go figure.
                            Their plug and play ability saw many returned in little black chunks.. however when properly set they were indeed great.
                            Were Castle logging buffered mean averages, or actuals ....... the hifei logs spikes and all ..... you can edit the log to follow voltage drifts under load super handy info
                            reverse ? oh my ... yes I see a few benefits, but hardly worthy the applause.
                            stick with it .. when you have the setup right it will truly impress ......
