Swordfish Pro+ 220 Running Hot
  • rickwess
    • Apr 2013
    • 777
    Boat: Insane Mono 34
    Motor: TP4060 2040kv (5D)
    Battery: 4s2p (Thunder Power 5000mah 70C)
    Prop: x447/3
    ESC Settings: 2014-06-01 09_31_52-Untitled - Hifei.jpg
    I've been having some NOOB issues dialing in the boat, but I think I have it right now. Just a little chine walk but I can now run the boat WOT now without fear.......kinda.
    The ESC is running VERY HOT. So hot that the heat shrink on the motor wires is softening and can be moved around. All 3 wires. That in itself tells me its a current problem. The batteries and motor are fine temp wise. When I tried to pull the data log it failed and the Hifei program closed. I pulled off the heat shrink and all looks fine. I'm out of heat shrink at the cottage so I might just tape it up with electrical tape to see if I can run it for a minute and pull a log.
    Important Note: This ESC was submerged when powered early in it's life. On one of the first runs, the boat had flip that peeled a strip of the hatch tape off. By the time I got to the boat it was bobbing vertical in the water. It sat burried in rice for a week and it seems to work OK except for the excessive heat.
    Any thoughts and advice would be appreciated.
  • oscarel
    • Dec 2009
    • 2373
    What does intake on rudder look like?
    Should look like this http://manuals.hobbico.com/aqu/aqub24-25-tech.pdf to allow ample water flow.
    Edit: never mind, looks like you have it right. Saw your thread in the boat building section.
    I'm in the process of setting up same boat/motor combo but will use a different controller.
    • rickwess
      • Apr 2013
      • 777
      Yes, it's a Speedmaster with dual pickups. Lots of water flow.
      I think it's excess current related. I'm going to prop down and hopefully be able to pull a log this time.
      • Jareth
        • Mar 2014
        • 63
        I think that's the problem too prop i down try an 2 blade prop the x445/2 or the x442/2
          How hot actually is the ESC itself? Judging the temp on the wires alone tells half the story: it can be a soldering problem, it can be that your connectors are not up to their task, what size do you use?
          I have had hot motor wires but the ESC itself was not over heating, just saying...
          BTW, I ran mine with X447/3 w/o issue, 4s2p , Castle-Neu 1515 1y 2200kv. Dinogy 5000mah 65c and 6500mah 65c , all 4s packs. ESC is CC Hydra Ice 240.
          • rickwess
            • Apr 2013
            • 777
            They are 6.5mm. The whole ESC is hot.........caps, body, wires.
            Going out now to run it with a m445 and hopefully be able to pull data afterwards.
            • rickwess
              • Apr 2013
              • 777
              Ran it for 1 min on a m445 and brought it to check temps. It was cool. Ran it for another 2 minutes and it just stopped out in the middle of the lake. I suspect thermal shutdown, but I can't pull the data log.
              I get the following error on a Windows 8.1 OS:
              Edit: I just found out that you can't install the HeFei SW in the default directory. I installed it to my RC folder and it works OK now.
              • rickwess
                • Apr 2013
                • 777
                Here's the logs from the last run. It's running hot (75C = 167F), but the current looks OK.
                I can only conclude that a) I don't have enough water flow or b) it was damaged in some way when it was submerged.
                When I blow compressed air into each of the water pick-ups it shoots whatever water is in the system out quite forcefully. When it's in the water, how hard should the water stream be?
                Edit: There's something about the temperature curve that is bugging me. The temp drops 30C in about 10secs at one point. The throttle position was low, so I assume that was when I was bringing it in to check the temps.
                • oscarel
                  • Dec 2009
                  • 2373
                  That's the reason I was asking about the intakes on the rudder. Make sure the slits go all the way to the end of the rudder. I have to tywrap my water lines on so they don't get blown off on a few boats.
                  • rickwess
                    • Apr 2013
                    • 777
                    I'm not sure I can improve on this though.
                    They are low enough in the water and the leading edge is lined up with the leading edge of the drive dog.
                    • Jareth
                      • Mar 2014
                      • 63
                      Use one of the inlets for your esc and the other for the motor
                      • rickwess
                        • Apr 2013
                        • 777
                        Both are being used.
                        • Fella1340
                          • May 2013
                          • 1025
                          I wonder if switching the lines around so the esc is being cooled from the other inlet might help, atleast it might rule out water flow to the esc. Just a thought
                          • Jareth
                            • Mar 2014
                            • 63
                            But use one of the inlet to cool the esc and the other inlet to cool the motor
                            • Jareth
                              • Mar 2014
                              • 63
                              Can you send a pic of the inside of the boat please
