swordfish pro+ 300a esc need help!!
  • out of stock
    • Jan 2014
    • 123
    guys, im kinda stuck at the moment trying to figure out how to program my sf 300a esc.
    i dont know how to set it. would any of you happen to know what settings it needs to be on?
    my setup:
    segad 56"
    -leopard 5698 835Kv 4D 8mm Shaft
    -8s (4x 4s 5000's)
    -70mm aluminum prop
  • Jlov
    • Nov 2013
    • 825
    You have the Swordfish program box? Where in Fl are you?
    • out of stock
      • Jan 2014
      • 123
      fort myers fl. i have the usb link that came with it along with the software.
      • photohoward1
        • 1781
        Did you install the software? If you didn't it has to run on any drive but the C:/ drive... Auto timing is what I use. and set it for 8s....No Brake, No reverse, Linear throttle. What else would you like to know.
        IMO you might want to start with a smaller prop. It should work but maybe sneak up to it.
        • out of stock
          • Jan 2014
          • 123
          very relevent thank you. i will have further questions coming soon as i dont have the software on me. its on a friends laptop.
          there were several other settings. i will get back tomorrow thnx alot.
          • grsboats
            • 1011
            With software it won't be difficult to set properly this esc...I have two working great. Gill
            GO FAST AND TURN RIGHT !
            www.grsboats.com.br
            • out of stock
              • Jan 2014
              • 123
              ill just need someone to give me a run down on each setting for my given setup. thank you all.
              • out of stock
                • Jan 2014
                • 123
                okay i need someones help getting this esc programmed.
                my friend and i programmed it and it seemed to run okay however when i give full throttle and let go it stops instantly. isnt it suppose to stop softly?
                LEOPARD 5698 D 835KV
                8S
                parameter setting
                LVC = auto/5.0v/2cells/7.2v/8.4v/3cells/4cells...all the way to 20cells. (obviously 8cells lol)
                BRAKE TYPES = NO BRAKE/SOFT BRAKE/HARD BRAKE (currently on soft brake)
                CUTOFF TYPE = SOFT CUTOFF/HARD CUTOFF
                PWM RATE = 8KHZ/12KHZ/16KHZ (currenly at 8KHZ)
                CUTOFF VOLTAGE/CELL = (I havent set this cretiria yet. my options are 2.5v to 3.3v)
                TIMING ADVANCE = LOW/MIDDLE/AUTO/ 0 DEGREES TO 30 DEGREES
                START UP TYPE = SOFT/STANDARD/FAST
                THROTLLE RANGE = (IT DOESNT LET ME SELECT THIS ALTHOUGH IT SAYS FADED "520" NUMBER ON IT)
                guys help me out here. thanks
                • Rocstar
                  Joel Mertz
                  • 1536
                  Change to No Brake. Throttle will be proportional. Also set the startup to Soft.
                  • photohoward1
                    • 1781
                    No brake!
                    • out of stock
                      • Jan 2014
                      • 123
                      thanks but what about everything else?
                      • Rocstar
                        Joel Mertz
                        • 1536
                        Soft cutoff. Cutoff voltage you can set to 3.2v but if you experience the controller limiting throttle during acceleration you may have to lower this value and time your runs. Timing, I like to set at around 2° for D wind.
                        • kevinpratt823
                          • Aug 2012
                          • 1462
                          Can anybody explain to me how this "auto timing" works? I've always been reluctant to use it, what does it base the automatic setting on?
                          My private off road rc track
                          • out of stock
                            • Jan 2014
                            • 123
                            ^ good question
