New Swordfish 120 Stops running?
  • kacordy
    • Oct 2012
    • 484
    I'm trying out my first SF 120 plus. If I run a prop bigger than a 442 it stops running after about a 10 second run. It comes to a stop and then restarts. Is it the Temp sensor shutting it down? Phil Thomas, Phil's recommended set-up, 2030 etc. I will order the link so I can check my data. Very Disappointing. Props that shut it down x-445, M-445, M-545, H-7. End bell is 120, Hyperions at 95. How are you guys running in the low 50's????
    Thanks for the Advice, Allen
  • photohoward1
    • 1781
    What is your Lipo Cut off set at?
    • flraptor07
      • Aug 2013
      • 2451
      Either the link or it's easier to use the programer, you can change settings at the water http://www.offshoreelectrics.com/pro...hef-programbox What boat are you running?
      • kacordy
        • Oct 2012
        • 484
        I have it in "Auto" with the programming box. timing is 10, fast start. I'm running 2 packs. 4s2p I believe is the term.
        Allen
        • flraptor07
          • Aug 2013
          • 2451
          Allen
          Take it off Auto and set it for 4s and set the LVC @ 3.0, set normal start, and timing @ 5deg. (low) see what happens
          • kacordy
            • Oct 2012
            • 484
            Perfect, I will give that a shot.
            Allen
