Help programming Swordfish Pro 220 ESC
  • Jlov
    • Nov 2013
    • 825
    Awesome thx Tim. About to walk out back and take first run. I have to admit I'm a lil nervous after initial maiden voyage...
      Goodluck! You will have a great time!
      Sent from my Droid using Tapatalk 2
      • Jlov
        • Nov 2013
        • 825
        What do you think about the suggestion to set timing at 12* Tim? Thx Jeff
          If its a "Y" motor, 12* is good to go, I don't know what settings are allowed on a Swordfish ESC. I set mine on 15 with Seaking.
            If you use a "D" wind motor (0) Zero degrees timing works very well.
            • rude5150
              • Feb 2014
              • 339
              Are you serious? I though it was 15.
                15* will just give you heat and amp draw. 10-15 on a Y wind yes is o.k. and there is an optimum for every motor but, D winds I set my ESC's to zero and they are happy.
                • martin
                  • 2881
                  D wind 5 degrees or under.
                  • ezhitz
                    • Aug 2009
                    • 466
                    One more programming question. I have the LVC set to 2 cells as I'm running 2s lipos. Do I set the next setting which is LVC per cell to 2.8v ? Thx Jeff
                    If your running as 4s should you not set the esc to 4s not 2s ! I believe you said running in series.
                    :canada
                    • czegard
                      • Nov 2012
                      • 153
                      Thank you guys, this thread is really help full! I finally set up my ESC.
                      Sent from my Nexus 5 using Tapatalk
