Swordfish Pro 200 and 220
  • Chilli
    • 3204
    Steve recently got some Swordfish controllers in stock. What's the word on the Pro 200 and 220 controllers? I'm debating trying one out for a P-Mono heat racer. Anyone have any input??
    Mike Chirillo
    www.capitolrcmodelboats.com
    Got a couple 220's, seem great so far. Watch the hard start setting. If you go to putter in it can jump.
    • HTVboats
      • Jun 2011
      • 936
      I bought two of the early 220's from KBR and for whatever reason they would cut out similar to when you hit low volts on "D" winds. No problem with "Y" motors. Other than that I have had good results with SF200 esc's. 300a not so much.
      Mic
      Mic Halbrehder
      IMPBA 8656
      NAMBA 1414
      • flraptor07
        • Aug 2013
        • 2451
        I've got 220 pro pluses in three of my boats and all run great Y and D wind motors. I've also got a pair of 200 pro pluses for a Cheetah twin build I'm doing, haven't run those yet but I'm sure those will work fine too.
        • dennislawler11
          • Sep 2013
          • 65
          i have a leapord 4082 that keeps cutting out with the sf 220+ what is doing that?
          • flraptor07
            • Aug 2013
            • 2451
            What do you have the LVC set at? and what is the rest of the setup on the boat? KV, Prop, size of boat, batteries, ETC.?
            • dennislawler11
              • Sep 2013
              • 65
              it is a 34 inch tunnel 2000 kv x447 prop 4s 5000mah 45-90c it says the lvc should defalt to 3.2. my usb link for the esc should be here tommorow.
              • flraptor07
                • Aug 2013
                • 2451
                Everybody is different but I set my LVC @ 3.0 volts. What kind of temps is it running? That might be a little too much prop for that setup try backing up to a 44 or 45mm prop and see if it still does it
                • dennislawler11
                  • Sep 2013
                  • 65
                  the temp seemed normal i will try backing off the prop thank you
                  • dennislawler11
                    • Sep 2013
                    • 65
                    it does seem to cut out even out of the water. is that normal?
                    • 427srule
                      Racer
                      • 188
                      Dennis,
                      I am running a SF220+ with data logging and 4s in a few different boats.
                      Had a few instances were the boat stopped during testing. I checked the amount of amps and it was as high as 280. This controller is only rated for 220 amps continuous. I had way too much prop.
                      When I propped down everything was good.
                      Check it out
                      • dennislawler11
                        • Sep 2013
                        • 65
                        would it do that even out of the water?
                        • flraptor07
                          • Aug 2013
                          • 2451
                          It shouldn't do it out of the water because there's no load on it, if it's doing it out of the water you got other issuses
                          • T.S.Davis
                            • 6266
                            What kind of experience are people having racing these? Guys have them in our club. I've never really checked them out though.
                            Be careful with the LVC on good cells. I set mine at 3v too but my GP packs and even some of my oldest Hyperians will deliver 3 volts until the tank is stone empty.
                            Noisy person
                            • iridebikes247
                              • 1669
                              I ditched the LVC cut off with my seaking escs now they're fine. With high quality packs like dinogy I didn't have a problem but with my zippy packs I was hitting lvc.
