200A Swordfish Pro in a rigger?
  • RandyatBBY
    • 3943
    First off Thanks to Steve for helping so much. I am going to run 200A Swordfish Pro in one of my boats to test and make sure it is good to go. It belongs to a friend that is a little of a newbe. How about in a rigger with 4S 2P, 1527 1D, X447 prop I ran it with a ABC 1816 prop and a CC 240 LV nothing to write home about but it moved. I have not had a lot of time running this setup. Should I go to a 30 inch sport and 1515 1Y on a 640?
    Uploaded with ImageShack.com
    Randy
    BBY Racing
    I am also getting my rigger back going with the 1515/ Swordy combo. I was thinking a 440 to start then up to 640. It went good before with that. Noticed a slowdown on a bigger prop though. Had Lehner in it then though,hoping the Castle has more torque.
    • photohoward1
      • 1781
      I am running a SGX20 with a 1515/1y 2200 (4200 cells 1P) and an H7 prop. Seaking 120. pulling about 80 amps and going 63mph. Never gets hot. I am sure I could go bigger the current prop has about 2.95" of pitch. This was my P spec rigger. Way more reliable with Full P power.
      • RandyatBBY
        • 3943
        Thanks guys I have not ran much other than my 40.160 and Castle 120 and 240 lv. I appreciate the advise. What is a SGX20?
        Normally I just go to the pond and test but my pond had been real low this year due to construction. I have to walk down the cliff side about 50 ft. And at 65 years young my legs do not hold up so well.
        Randy
        BBY Racing
        • photohoward1
          • 1781
          Andy Brown SGX20
          • RandyatBBY
            • 3943
            I should have known that duh moment.
            I really need to know the 200A Swordfish Pro capability's.
            Randy
            BBY Racing
              You mean max amps?
              Or what info can be extracted. If you mean programming, there is a lot more with USB link than the old box.
              • RandyatBBY
                • 3943
                No I was speaking about the motor, prop and cells.
                I hooked up the ESC to the computer and it does not read. I have three new ESC one out of the three will read on the computer. I get "Cant find hardware O1MS's parameter settings" Just my luck lately. Now I do not get to test it on Sunday.
                Randy
                BBY Racing
                • photohoward1
                  • 1781
                  What drive did you install the program on? You need to instal it on anything but the C; drive.
                    I have also been having issues with the programming all along. Somebody posted some updated software the other day either here or on Keith's site. I'll look when I get a chance.
                    • RandyatBBY
                      • 3943
                      That did the trick! Thanks, I installed HiFei program on my external hard drive E:/ now it will read the other two ECS's
                      Randy
                      BBY Racing
