Problems with SF 120 telemetry
  • RandyatBBY
    • 3943
    I set up and have used the telemetry with my SF 120 a few times. Today the computer that has worked the best said that the com port was invalid no matter which one I changed it to same thing. How can I make this work? That is to get the correct com port?
    Randy
    BBY Racing
  • iamandrew
    • 576
    are you actually using a COM port?
    every time you plug one of those USB to COM port adapters in, the COM port number will change depending on what USB port it was plugged into
    • RandyatBBY
      • 3943
      I am plugging it in to a USB. It says "Invalid com port" I thought it was automatic.
      Do I just need to reload the software or restart the computer?
      Randy
      BBY Racing
      • Arizonaheat
        • Mar 2013
        • 43
        It depends...some of the earlier S/W versions required you to manually set the COM port with your Device Manager...the latest version 4.01 is supposed to automatically set the COM port for you.
        • RandyatBBY
          • 3943
          I never set it before and it worked.
          Randy
          BBY Racing
          • iamandrew
            • 576
            hmm COM1 is usually a physical port on a computer or (old) laptop, Mice used to use like COM port 1 or 3.
            its possible using USB your actually using COM port 4 to 8 or so
            youd have to plug it in, then go into device manager, look at the USB stuff there
