Swordfish 120A ESC on 5S?
  • bigwaveohs
    • 606
    Wondering if it's a bad idea to run a Swordfish 120A ESC on 5S with an ARC 1850kV in a JAE 21?
    I let the dogs out...
  • MAMBA2200
    I need a scooby snack
    • 1347
    you should be fine on 5s thats gonna put you about 33-35,000 rpm i would just run for a minute and check temps and run another min and check again i run a 1900kv on a 120 seaking and it does good all dependent on your prop selection i use a m454 on that setup
    • bigwaveohs
      • 606
      Thanks.
      I was thinking about starting with a pitched H5 (45.1 x 80.8 x 114.3 mm) or my m445 (45.1 x 73.7 x 95.3
      mm); third number is the added cup.
      The stock X445 is about 45 x 63 mm, so my m445 is closest except for the cup.
      Pete
      • MAMBA2200
        • 1347
        I meant to put m445 my bad
        Sent from my DROID RAZR using Tapatalk 2
          I added 1000uf 35v caps to my 120a esc,
          Helps keep thing cool.
          • bigwaveohs
            • 606
            Yeah, I've got a 454 but it's in my other boat...
            • MAMBA2200
              • 1347
              Very nice
