Swordfish opinions
  • MAMBA2200
    I need a scooby snack
    • 1347
    Swordfish opinions
    i was just wondering if anyone has used the new swordfish 200 with data logging here is the link http://www.offshoreelectrics.com/pro...f-sword-200%2B was thinking about getting one and wanted some thoughts about i have heard that the last version there was allot of them that would just burn out so if you have used or have knowledge of this esc please give your thoughts thanks
  • MAMBA2200
    • 1347
    anybody ??
    • RandyatBBY
      • 3944
      I am looking for some info on the new Swordfish Plus. I have a 120A and a 200A So far I have it calibrated and trying to get the soft ware installed. Castle had a learning curve hope this will instigate more info on the ESC's.
      I need to get the motor to spin freely and the card did not do it. both settings make it a hard stop
      Randy
      BBY Racing
      • RandyatBBY
        • 3944
        Well after about 2.5 hours I got the software installed and working. My brain is tired.
        Randy
        BBY Racing
        • keithbradley
          • 3671
          I haven't ran the 200s yet, but I have been running the 15/300s and 12/240s and they have performed flawlessly. The only issue I have had is I can't get the data loggers to download on my laptop with windows 7. It works fine on my PC with XP though.
          www.keithbradleyboats.com
          • HTVboats
            • Jun 2011
            • 936
            I have a couple of the older SF 200's and one new one with the data logger and all are working just fine. If I can figure out the data logger it has to be simple. Set a couple 2 lap records with them. I have pushed them to the point of motor leads desoldering and the only failure so far (knock on wood) has been due to submersion which falls under the category of operator error.
            Mic
            Mic Halbrehder
            IMPBA 8656
            NAMBA 1414
            • devo
              • Aug 2012
              • 156
              I had one that Ive been running for about 2 months fail last sunday, this is the setup that burned. Fightercat rivercat 32. Tacon 2150kv 4074. Stock prather prop off new blackjack around a 442. Swordfish 200amp esc with data logging. And two gens ace 7.4volt 50c 5000mah batteries in series. Unit did not get wet and was not even warm after 3 minutes of run time, at which point I gave it to my son and told him to have fun but take it easy. He ran it for about 10 minutes and I told him to bring it in after next lap, at that point it made it about 20 feet from the shore and stopped at which point it looked like the miami hurricanes were about to take the field. When i got it in all that was wrong was the esc was burn up but the batteries, motor and boat were all fine. The water cooling was working fine and I dont think I was over powering it by any strech of the imagination.
              • T.S.Davis
                • 6266
                Keith, how many amps have you pulled from the 300?
                Noisy person
                • jcald2000
                  • 786
                  All that time of your son running part throttle probably killed it.
                  Partthrottlee for any greatlengtht of time will kill any ESC as the FETS try to hold back the amps.
                  • ALIENALESSIO
                    • 80
                    Hofei Software
                    You have to save the installation on different disk, not C any other is fine or a pendrive then it'll work fine. it's beacause Win7
                    has a high protection on running some software. Just install and save on anthing but not C disk
                    • ALIENALESSIO
                      • 80
                      I have the new 220amp Pro and had a some runs with no issues at all on my 21Rig , will be testing also the new 120 Pro on smaller Rig
                      Also testing the lateset firmware and updated V4.03 program also.
                      Personally I think that the data log at times is not 100% correct looks like amp draw at times is incorrect since it varies a sensibly although TH is 100% and there is no load
                      variation on motor during bench testing.
                      • devo
                        • Aug 2012
                        • 156
                        [QUOTE=jcald2000;471232]All that time of your son running part throttle probably killed it.
                        Partthrottlee for any greatlengtht of time will kill any ESC as the FETS try to hold back the amps.[/QUOTE
                        I Totally agree with what you're saying because when I ran the boat it didnt Even get warm. But my son has ran all my other boats for long periods of time and never had this issue, But it was always a 36 mm motor not a 40.
                        • T.S.Davis
                          • 6266
                          I think I'm sold. Bring on the amps!
                          Noisy person
                          • steveo
                            • 1595
                            i have a swordfish 200 plus i used only once so far the data logging worked great once my wife helped me with it, i had the older 200 version and it worked great
