Wiring for swordfish 300 pro
  • pfish
    • 28
    I'm trying to wire the swordfish pro 300 to two batteries in series as described in the instructions given by the manufacturer. The problem I'm having is finding connectors for the 8MM wires.
    The red leads need to be Joined and the black leads need to be joined and then have a one positive wire, and one negative wire coming off of them. I need a clean way to make a Y connection.
    Can someone give me a solution?
    Thanks
  • LOVE6S
    • May 2012
    • 538
    How about you plug the pos from one batt to the neg of the other and then plug the red to red on esc and black to black on esc, that will give you a series, a Y is usually paraelle conn.
    • LOVE6S
      • May 2012
      • 538
      You have to have say two single 5,5 conn or larger on each batt. and one on the red and one on the black of the esc.
      • pfish
        • 28
        This what I have.
        • LOVE6S
          • May 2012
          • 538
          Send a pic of the the wire set up below the one you posted please. That one you posted looks like paraelle to me.
          • pfish
            • 28
            I think your right. But the instructions seem to demand it. I'm new and learning. Thanks for your patience.
            • LOVE6S
              • May 2012
              • 538
              I am not a pro myself, but know some stuff and learing every day, the pic they show is paraelle, what are you running for lipo packs?
              • LOVE6S
                • May 2012
                • 538
                What ga is the red and black wires on the esc?
                • LOVE6S
                  • May 2012
                  • 538
                  Do you know how to solder?
                  • oscarel
                    • Dec 2009
                    • 2373
                    If using two lipos in series it would represent one of those in the photo. I would still wire as pictured in case you need parallel in the future.
                    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
                    • LOVE6S
                      • May 2012
                      • 538
                      Isnt the pic with a green check mark a paraelle?
                      • oscarel
                        • Dec 2009
                        • 2373
                        Yes it is. Is it necessary to run parallel? Only if needed. I would imagine though that if you have a 300amp capable esc that you'd probably need to run parallel.
                        • oscarel
                          • Dec 2009
                          • 2373
                          This picture would ASSUME you've added the jumpers per the instructions, neg - neg/pos - pos. You have the ability to add 2 sets of series lipos without using Y connectors. Protect the unused leads if you don't plan to use parallel.
                          This would be if you wired neg - neg/pos - pos at the connector. If you need parallels you will have to use a Y connector.
                          • oscarel
                            • Dec 2009
                            • 2373
                            See post #47
                            http://forums.offshoreelectrics.com/...h-data-logging
                            • pfish
                              • 28
                              I'm using two 3 cell 8400mah lipo's 25c 11.1v. thanks for the help. I'm looking for hardware to make this clean.
