Swordfish 120 Amp ESC and Leopard motro
  • dariomonguio
    • 136
    what Time advance to Swordfish 120 Amp ESC and Leopard motror 4074
  • Steven Vaccaro
    Administrator
    • 8932
    Auto timing. Which kv motor and cells are you using?
    Steven Vaccaro
    • dariomonguio
      • 136
      timmin
      2000 r/v 6s lipo 6000 hiperion, boat Riguer
      2200 r/v 5s lipo 6000 hiperion, boat Riguer
      and what to neu 1512- 2600rv?
      • Steven Vaccaro
        Administrator
        • 8932
        On 4s its probably pushing more than 100 amps. Those setup are more than a 120 amp esc will handle. I would definitely not run the 120 on those voltages and rpms.
        Steven Vaccaro
        • dariomonguio
          • 136
          timing
          2000 r / v 6s lipo 6000 Hiperion, barco Riguer , Swordfish 200 Amp ESC
          2200 r / v 5s lipo 6000 Hiperion, barco Riguer , Swordfish 200 Amp ESC
          y qué neu 1512 - 2600rv? 4s, Swordfish 120 Amp ESC
          • Steven Vaccaro
            Administrator
            • 8932
            2000 r / v 6s lipo 6000 Hiperion, barco Riguer , esc 200 a
            2200 r / v 5s lipo 6000 Hiperion, barco Riguer , esc 200 a
            y qué neu 1512 - 2600rv? 4s, 120A
            I personally have not run a 2200 on 5s to know the results. But I have run a 2200 with 4s and 6500 hyperion 35c packs. (1) 4s pack was not enough. I had to run (2) 4s packs in parallel for good results.
            Steven Vaccaro
            • dariomonguio
              • 136
              4s
              in Spain the regulation only allows 1P
              races are 5 minutes oval.
              and weight of batteries is limited
              Oval 1 (2s1p) 300gm
              Oval 2 (3-4s1p) 590 gr
              Oval 3 (5-6s1p) 895 gr
              what you have rules of racing oval in the united states
              what time?
              what battery?
              what category in riguer oval?
              • Steven Vaccaro
                Administrator
                • 8932
                For racing we have a 10,000mah limit. For heat racing its a number of laps.
                Steven Vaccaro
                • Basstronics
                  • 2384
                  I got a low end KD3660 3000KV motor pulling well over 120 amps. I also have a Leopard 4074 2000 KV on the shelf here. After seeing an Eagle Tree on the KD3660 not a chance I would put a 120A ESX on that Leopard. Im not sure if 180 would be enough.
                  • Ronbo
                    • 122
                    A fellow scale racer that Im going to copy ran a leopard 2200kv, 442 prop, and 120amp speedo on 4s1p and did fine in a scale hydro. i ran against him and he had a lot of power and easily lasted 5 laps. Our courses are not small. fwiw...
                    Ron
                    1/10th 2014 U-6 Oberto ,1999 U-6 Miss Madison, 1971 U-6 Miss Madison, 1976 U-6 Miss Madison Unlimited Hydros
