Swordfish 120 wont go to full throttle!
  • britscoot
    • 721
    Anybody else had this problem?
  • Rumdog
    • 6667
    Is it programmed for the correct voltage?
    • britscoot
      • 721
      i think so.
      I have that little card with the dip switches.
      Could that cause it?
      • Diesel6401
        Memento Vivere
        • 4391
        Did you do the throttle calibration?
        - Diesel's Youtube
        - Diesel's Fleet
        • britscoot
          • 721
          Calibration was done a while ago.
          it worked properly then this problem came up.
          is there away of re calibrating?
          Thanks all for the help.
          • Diesel6401
            Memento Vivere
            • 4391
            Check all the connections first if all are good re-calibrate the throttle. The re-calibration is the same as the first time you calibrate.
            Pistol style transmitter calibration
            - Correctly connect the ESC with brushless motor, plug the receiver lead of ESC into receiver ( usually into
            Channel 2);
            - Put the throttle to the forward full position, turn on the transmitter;
            - Power on the ESC, there are 3 beeps emitted from the motor, which indicates all electronics are correctly
            power on for the setting.
            - Then there are 4 long beeps emitted from the motor ♪ ♪ ♪ ♪ .
            - During or after the 4 long beeps , move the throttle to the neutral position. Two beeps emitting out
            indicates calibrating is completed.
            - Following two beeps are powering beeps, it is time to go now!
            - Diesel's Youtube
            - Diesel's Fleet
            • britscoot
              • 721
              Its not beeping but i get throttle.
              Just not full throttle.
              Whats the correct settings ie cut off etc?
              I sometimes get a red light on the esc when i pull the trigger to full.Motor spins.
