8xl on swordfish 120?
  • sharkbite
    • Aug 2009
    • 392
    Hey.
    I dont know if i can do this. But will a swordfish 120 work on a 8xl with a x442 prop and 4s? I just what to know if the esc will take it
    thank you.
  • JMSCARD
    • Mar 2010
    • 4174
    Originally posted by sharkbite View Post
    Hey.
    thank you.
    what kind of hull would be helpful.... only because you are definately on the edge....
    • sharkbite
      • Aug 2009
      • 392
      32" cat
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        hmmmm I say no. I've used it successfully in a hydro but in my small (26") monos they didnt survive.
        • marko500
          • 862
          If it's a Feigao 8XL their chart says 83 max amps for that motor. I ran a Hacker 8XL on 4s on an ETTI 150 and a Castle 120 with no problems in a 32" cat. I think I also ran a X442 prop. If I remember my temps were up there but not terrible. If you decide to run it I would keep an eye on temps. I'm no expert just stating my personal experience.
          Mark
          • sharkbite
            • Aug 2009
            • 392
            thanks guys for the help
            i thank i will wate for the swordfish 200amp.
            • Make-a-Wake
              FE Rules!
              • 6057
              I run an 8xl with a 120a..............i think it will work with a 440 for sure
              • keithbradley
                • 3671
                I ran a Leopard 4074 2200kv on a swordfish 120 (in a sv27) and it didnt break a sweat. They seem to be pretty tough little guys untill they get wet (oops!).
                It may not be the ideal esc though...you do have a larger hull.
                www.keithbradleyboats.com
                • video200
                  • 840
                  just a little note.
                  those 83 max amp is the factory recommended MAX continuous use and NOT what a 8XL wil draw if over propped.
                    You could start with a CF 42mm prop, it has less load than 442.
                    • marko500
                      • 862
                      I've got a couple of smoked ESCs to prove not to only trust or go by those numbers. But at least it gives you some kind of idea on a starting point. And of course prop small and work your way up. In my lifetime I've learned alot of things the hard (expensive) way! LOL
