swordfish 240hv users
  • boatinjoe
    • 54
    I bought the program box, figured it out, set to auto lvc it will beep 10 times , running 10-s so I guess that means 10 cells . when I hit throttle nothing, hit brake it starts and revs to the moon, I switched servo (reverse) via transmitter still does the same thing will not shutdown, thank goodness for that little switch . help please I want to go out and play today joe
  • boatinjoe
    • 54
    ok I went back printed up the sequence, restored esc to default settings, tried transmitter calibration hooked it all back up, motor does not run all I get is different tones ...... this is crazy, at least with castle I could call tech hotline. I know its a holiday, maybe no hv240 users on today. this is supposed to be enjoyable.NOT
    • Rumdog
      • 6667
      Try holding full forward throttle, then plugging in. Hold throttle thru the first seies of beeps, the let off to neutral.
      • Diesel6401
        Memento Vivere
        • 4391
        I know my 120 would not work right until I turned the throttle trim all the way to the clockwise position (Tactic Radio).
        - Diesel's Youtube
        - Diesel's Fleet
        • boatinjoe
          • 54
          ok so we might be getting somewhere here, now the motor revs and slows down but only by forward motion of throttle== brake
          • Flying Scotsman
            Fast Electric Adict!
            • 5195
            What radio are you using?
            Douggie
            • boatinjoe
              • 54
              futaba 3pk 2.4 module 603fs reciever
              • Flying Scotsman
                • 5195
                I do not own that ESC but this sounds like a program problem...remove all auto settings and see what happens.
                Douggie
                • Diesel6401
                  Memento Vivere
                  • 4391
                  Now try adjusting the throttle trim until it stops when trigger is in neutral. Leave the trigger in neutral if the motor slowly turns keep adjusting trim til it stops. Your radio should save the position I know my spektrum does.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • boatinjoe
                    • 54
                    the only real auto setting it has is lvc, and its not beeping twice then counting/beeping 10 times anymore. I will try thanks
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      I know it took me a while to get my 120 to play nice. After that it was fine.
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • Flying Scotsman
                        • 5195
                        Also set all your radio trims to their default positions, and then reprogram the ESC
                        Douggie
                        • boatinjoe
                          • 54
                          I took out braking, also known as boat mode, nothing then removed 3wire form esc and hooked up a servo , and I do have throttle. servo works fine ,so power is being sent to esc , I did fail to mention that I am using a littlescreamer , what next
                          • boatinjoe
                            • 54
                            well still no luck, my brain is frazzeled over this, gonna sleep on it ,try my scorpion 5035 on it tommorrow and see if its the motor or what. I will say this when it ran was pretty impressive
                            • DISAR
                              • 1137
                              I managed to set mine in the following way with Futaba 2PL
                              a) transmitter, throttle REV, trim B 25,
                              b) esc, switch OFF, connect main battery and rx bat, hold full throttle then switch on the esc ON
                              c) while the 4 beeps sound, move throttle to neutral
                              it should work. to check again, turn the esc off and then on with the throttle in neutral
                              http://www.rcfastboats.com/
