Swordfish ESC problems
  • JohnZ
    • 267
    I can't get mine to arm when using a Hitec Agressor 3 FM. I've tried different trim setting on the throttle channel of the transmitter but can't seem to get the proper response. I also used the programing card to double check the settings but still can't get the esc to arm. I was able to arm it and get it to function with a Hitec Fm air radio so I know there isn't a problem with the esc.
    What am I missing here?
  • Diesel6401
    Memento Vivere
    • 4391
    Did you do the throttle range set-up? Did you try using the reversing switch for the throttle.
    - Diesel's Youtube
    - Diesel's Fleet
    • electric
      • 1973
      I vote the reversing throttle switch as stated above. I was going crazy with that same ESC and then "click" to reverse and all was well...
      • sailr
        • 7128
        If all else fails, maybe you need a pistix. ??
        Mini Cat Racing USA
        www.minicatracingusa.com
        • JohnZ
          • 267
          I try reversing the throttle.
          Don't know why I would need a Pistix.?
          • drwayne
            • 3012
            the 240hv needs more than 55% between wot and center off
            set wot endpoint +10%.. and try again.
            • sailr
              • 7128
              pistix changes the throttle range timing. Has nothing to do with reversing. If your radio allows you to set the end point adjustment, increase it for WOT.
              Mini Cat Racing USA
              • Steven Vaccaro
                Administrator
                • 8932
                you shouldnt need a pistix. When did you get the esc? There was a firmware change that was done to address a problem like this on the first batch.
                Steven Vaccaro
                • JohnZ
                  • 267
                  Steve I just bought it May 1st. What do I need to make the firmware change?
