Feigao 540 8xl and Hifei swordfish 120 a good como?
  • Jabbo
    • Jul 2009
    • 495
    I am looking to up grade my fastec would a feigao 540 8xl and a hifei swordfish 120 make a good set up to run 4s and sometime 6s on. Some day I would like to put it in a Challenger 31". Would this work?
  • BakedMopar
    No Mo Slipah
    • Sep 2009
    • 1743
    IME anything over a 29" mono would be pushing it. That setup is proven in a 25" delta clone but in a OM29 it's close.
    • Jabbo
      • Jul 2009
      • 495
      then what whould I need to bump it up to?
      • Xfactor
        • 874
        a 9xl will carry that boat
        • Xfactor
          • 874
          Im pushin a 26 inch paynpak with a 6xl on 3s. An xl motor in my opinion will push that boat as long as the battery prop combo is right.
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1743
            I'm not saying the motor won't push it. I would go to at least a 150amp esc for the bigger boat so you can prop accordingly.
            • ENCORE MAN
              • Jan 2010
              • 1096
              8xl
              I am running a Nemisis 8xl with an ETTI 150 IN A 26" H&M and the ESC barely gets warm. I had previously smoked a SEAKING and a TURNIGY 120 A in the same setup. You might want to spend more now and buy it only once. BG
              • Jabbo
                • Jul 2009
                • 495
                Hydra 240?
                • izzy7771
                  • Sep 2009
                  • 51
                  maybe a turnigy 180? i have had nothing ever go wrong with any of mine. i have 4. would buy more too if i smoked one. run them on 3s to 6s all the time. i like em anyway and they arent really that expensive.
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    Jabbo - "then what whould I need to bump it up to?"
                    The fastec is 27" long...............an XL motor will push it fine. I'd go 9XL for 4s if i were you. I have a 31" Villain nudging 40mph with a 12XL on 6s.................an XL will really move that boat out well!
                    • Jabbo
                      • Jul 2009
                      • 495
                      How is the Etti 150 with bec?
                      • ENCORE MAN
                        • Jan 2010
                        • 1096
                        8xl cont'd
                        THE ETTI 150 APPEARS TO BE VERY RELIABLE. I own two of them and have no regrets except with programming which takes awhile to figure out but once you get the rythmm, it is easy. BG
                        • Make-a-Wake
                          FE Rules!
                          • 6057
                          The turnigy 120a will run the XL motor just fine.....and up to 6s.......I own several, they are a great value............only$49 under my HK user login.
                          http://www.hobbyking.com/hobbyking/s...hless_Boat_ESC
                          • Xfactor
                            • 874
                            If somebodys gonna sell me a 180 amp 360 burst for under a 100 dollars id be crazy not to get it it obvious that rite now the most success is being had with the turnigy/seaking 180s. if you worried about the amps I think you better go there. I mean I chose a turnigy hv 80 over a hv 100 because the 80 had more burst amp capability u have to really look at these specs but i bet the mystery 200 will hold up. I have a forcemax 60 in my atlas no problems. A elf hobbys 100 in my pak on a 6xl no problems. So its really hard to say but go for overkill get the 180 turnigy.
                            • Xfactor
                              • 874
                              I just wish they made a HV 180 for a price like that.
