Swordfish Frustration
  • Eodman
    • 1285
    Well I'm taking a break from these freaking things. I finally got one them to run. But not the other one !
    Trying to set up a twin drive outboard MM. Took the y adapter out of the equation and hooked up just one to 4s and it ran --- set the other one up the same and nothing! WTF????
    I'm going to give it one more go tomorrow evening and if I can't get it -- I'm selling these things and using Etti 150's!
    Hey I wonder if these swordfish 120's will cook up on the grill?
    We did it with a Bang!
    Cats Are Where It's At!
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    If using two with BEC, the red wire must be removed on the receiver connection on one of the ESC sides of the Y connector.
    ( you may already have done this)
    Sometimes I can get them both to calibrate at the same time, other wise, I calibrate one side at a time, using the BEC connected side of the Y connector.
    I've found that the 70/30 w/throttle trim full helps with calibration.
    Good Luck, hope this helps.
    ________
    LANSING DELTA TOWNSHIP ASSEMBLY
    • BakedMopar
      No Mo Slipah
      • Sep 2009
      • 1743
      I have calibrated both of them together and run both of them with the BEC. They run cooler than CC hydras in my twin cat.
