seaking 180 problems
  • a53hoop
    • Oct 2019
    • 70
    i have a seaking 180 that has worked flawlesly for me so far. not much use so far. moved it into my new g30 tunnell.there are no beeps when powered up and seems stuck on 2s setting and boat is very slow.am using 4s battery and3660 lepard motor. any help pls. tks AL
  • Xrayted
    • Jan 2023
    • 273
    Are you using the exact same TX as you were using when the ESC was on the other boat? If not, then you must calibrate the throttle channel endpoints between the new TX and the new ESC. If the same TX, then nothing there should be the issue.
    Are you using a Futaba radio by chance?
    • a53hoop
      • Oct 2019
      • 70
      yes same thansmiter and reicver. spectrum dx5 and mr4000 reicver
      • jkflow
        • Aug 2021
        • 329
        Re-do the calibration, make sure throttle rate is 100% (if you have it) and throttle trim at zero. Throttle channel should be in 'rev' (reverse), else you will only get about 50% throttle.
