Anyone change the caps on a spectrum 120
  • Froggy
    • Mar 2023
    • 125
    Looks like the caps are blown on mine purchased it used, the caps are bulged on the ends thought I might try replacing however they are not available by any numbers on them
    • 4338
    Those are ZLH series caps made by Rubycon, which are easy to find. You need a minimum voltage spec of 35V. Existing bank is 1170uf total, so I would probably use 500uf as a minimum on the replacements since this is a low current capacity ESC.
    • Froggy
      • Mar 2023
      • 125
      Thanks for the reply, I jumped a bit too fast on this subject, I found them on e bay ��
      • jkflow
        • Aug 2021
        • 329
        Get more of them else you will blow them again.
        You had too much ripple which overheated the caps. Put 5 or 6 in parallel.
        • Froggy
          • Mar 2023
          • 125
          I purchased 10 of them, thanks
