I'm hoping Peter might chime in again (please)! I see others have struggled with ZTW setup as well.
In my case, I had no problem connecting the program card to set and save the the parameters. I have set my throttle limit (on a stick Tx, not pistol) to 100% in the full throttle position and to 0% in the reverse position. When I hold the throttle on full and plug in the ESC to calibrate, I get continuous beeps separated by about a second between each beep. This is the only kind of response I can get out of it. After that, if I reboot with the throttle in neutral, I still get the same beeps. Battery voltage is about 16.6v. In other threads I've seen some discussion about setting limits to 150% which I completely do not understand and discussion of something called Pistix. I don't know what Pistix is. If you have experiencing setting up these ESC's can you chime in please? I have no idea where to go from here. I know once I get through the set up this will be a great ESC. Thank you.
PS - If it is relevant, the battery leads are standard from the factory and they connect to a wire Y-harness which is maybe 4 inches long to put the two 4S batteries in parallel. I've read in some threads that wire length seems to be an issue but I don't think there's anything excessive here.
