ESC self programing
  • Chazz
    • Nov 2021
    • 4
    ESC self programing
    I have the veles 29 and burt my ESC, I purchased a new one plugged everything in, turned receiver on then ESC and it just keep beeping. My batteries are in storage mode didn't think that would be a problem.
    Anybody know if I am doing something wrong?
  • Panther6834
    • Apr 2020
    • 708
    Did you remember to calibrate the throttle? If not, that's the cause of problem.
    • Chazz
      • Nov 2021
      • 4
      The instructions said to keep the throttle at neutral, thats what I did. Says the esc will automatically calibrated the throttle range after 3 seconds
      • jkflow
        • Aug 2021
        • 329
        What is the make/model of your new ESC? If it's a stock replacement, you are doing it wrong.
        Dynamite 120A
        Ensure proper ESC function by calibrating the ESC to your
        transmitter inputs.
        1.Power OFF the ESC.
        2.Ensure your transmitter is powered ON, the throttle is
        not reversed, the throttle trim is neutral and the throttle
        travel range is at 100%. Disable any special functions
        such as ABS, etc.
        3.Pull and hold the Throttle Trigger to full throttle and
        turn the ESC on.
        4.After 2 seconds a “-B-B” will sound. This means the
        full throttle position has been confirmed.
        5.Release the throttle trigger to the neutral position, a
        steady long “B––” will sound. This means the neutral
        • Chazz
          • Nov 2021
          • 4
          I figured it out! Thanks for responding
            • 4340
            The new ESC needs a throttle calibration at a minimum. I would also connect it to a programming card to verify proper timing and other settings.
