Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Data logger with amp draw data - RcBoaters Forum
  • Logan
    • Jun 2021
    • 5
    I was wondering if there was any way to record amp draw while running boats on the water?
  • plinse
    • Oct 2017
    • 103
    Sure.
    I use the Unilog 2 from SM Modellbau:
    It can log current, Voltage, rpm based on detecting the phase frequency or optical measurement, Temperatures, ...
    There is a big variety on sensors you can connect, one option would also be a GPS-Tracker, ...
    Very nice system.
    Regards, Eike
    • Logan
      • Jun 2021
      • 5
      Thanks for input Eike. I will consider that option, although I would like to find a USA supplier. After searching around I have also found some esc’s with data logging that I’m considering.
        Castle ESCs have very good logging abilities. Sadly their marine support is lacking, but modding other controllers for marine use gives the option of using them for data logging.
        • Logan
          • Jun 2021
          • 5
          Thanx fluid, I’ll definitely look into that.
          • NativePaul
            Greased Weasel
            • 2770
            The SM modelbau Uniloggers are the best logger out there.
            MGM, and Hifei also make boat ESCs with datalogging, but if you want a USA based device I think your only options are modding a car or plane Castle Creations ESC for boat use, or buying a used Eagletree Elogger.
            • Logan
              • Jun 2021
              • 5
              Thanx Native, I’m liking the hifei swordfish 220
