Turnigy programming card?
  • Nick1979
    • Sep 2020
    • 118
    I have the Turnigy 90A Marine ESC, but I can't find a programming card for it. The original one at Hobby King has been out of stock for months now. Does anyone know for sure if any other card can be used? I have tried Flycolor and it did not work. Does anyone have a Turnigy Marine ESC card willing to sell?
    Post a picture of the ESC so I know what esc it is and I can help you out.
    Is this it?
      This is the program box for it.
      https://hobbyking.com/en_us/hobbykin...en_us_products
      • Nick1979
        • Sep 2020
        • 118
        It is the Turnigy ESC, and according to HK customer representative, no other cards will work, but Turnigy. Have you used the HK card on a 90A Turnigy? If so, I would get it right away. https://hobbyking.com/en_us/turnigy-rc-boat-esc-90a.html?queryID=d41005b41b1f307a695fb36c3b4be649& objectID=73851&indexName=hbk_live_magento_en_us_pr oducts
          Listen... HK has labelled half a dozen different types of ESC Turnigy ESC's. I need a picture at least to help you out. Is the one I posted the one you have???
            OK, the link you have in your post is a Flycolor esc and the flycolor esc program box will work if used correctly...
            https://www.offshoreelectrics.com/pr...prod=ose-R-box
            https://hobbyking.com/en_us/turnigy-...en_us_products
            I use this one because I've had it for a decade: https://www.ebay.com/itm/Hobbywing-P...sAAOSwImRYWN49
            • Nick1979
              • Sep 2020
              • 118
              I had no luck with the Flycolor card. Tried on my Turnigy 60A ESC, the display lit F L Y, and that was it. No way to do anything else. With the 90A ESC, pictured below, the program card didn't even turn on. Has anyone ACTUALLY done this combination? I guess I'll have to program with the remote. What a bummer...
              • nhk750
                • Oct 2019
                • 15
                You should be able to program it with the receiver and transmitter using the beep tones. It's much harder but I have done it on many ESC's.
                • Nick1979
                  • Sep 2020
                  • 118
                  I am having big trouble setting up the ESC. I just soldered the connectors and was ready to program it with the transmitter, following the instructions on the ESC. Only thing I get is constant beeping. I have a few seconds video I will try uploading here. Not sure what's going on. Any ideas?
                  P.S. apparently I can't attach a video file
                  • nhk750
                    • Oct 2019
                    • 15
                    Make sure your radio is binded to the reciever, then you may need to calibrate the throttle first. Esc's ususally just beep like that when theres no signal from the rciever or the throttle is not at low.
                    • Nick1979
                      • Sep 2020
                      • 118
                      Thanks! I reconnected the receiver wire and it all worked perfectly. It turned out not to be so difficult programming with the radio transmitter.
                      • Old School
                        • Aug 2017
                        • 686
                        Today I successfully used the Turnigy ESC programming card (as pictured in Ray's earlier posting) on my 150 amp Turnigy ESC. I have purchased the Hobbywing card as linked to by Ray to hopefully program my Turnigy 180 amp ESC. I just need to await a month or two for delivery. The 180 amp ESC was previously programmed, however, I will need a card should I decide to make changes in the future.
