First time modding a MambaXLX . Need input thought.
  • rearwheelin
    • 2101
    Scratched the oil bath idea and figured water cooled metal pulls heat better than oil. Everything is bonded with JB weld and I was careful to not short circuit the board by having a cured layer on all part that touch the board. I?m just curious if I completely destroyed this by possibly hindering its timing . I have but power to it and no explosive behavior so far. This thing has lots of heat pulling capacity for sure now only if it works correctly
    B1E98509-85D9-49FB-9602-6A8C375DE8F6.jpg5FE3E945-B674-4B22-8C09-F5A3696FCDB8.jpg527B6346-37A3-46F6-9F2D-4DA72D6B9E9E.jpg
    --Albert Einstein
  • NativePaul
    Greased Weasel
    • 2770
    Is JB Weld not conductive? I haven't used it myself, but have heard it uses steel as a filler.
    • raptor347
      • Jul 2007
      • 1177
      JB weld is definitely conductive. If you bridges the power input buses or the three motor phase outputs you probably killed it.
      From the first pic it appears you have the JB weld crossing "+", "-" and at least one output phase.
      Brian "Snowman" Buaas
      Team Castle Creations
      NAMBA FE Chairman
      • rearwheelin
        • 2101
        --Albert Einstein
        • rearwheelin
          • 2101
          No it is non conductive https://www.jbweld.com/faqs
          --Albert Einstein
          • raptor347
            • Jul 2007
            • 1177
            I stand corrected. It should be fine then.
            I usually just strip the case off, solder copper tubes to the power buses and re-conformal coat it.
            NAMBA FE Chairman
            • rearwheelin
              • 2101
              I’d like to see pics of that someday. I probably went over kill lol
              --Albert Einstein
              • rearwheelin
                • 2101
                It?s alive
                --Albert Einstein
