I have a 49" aeromarine donzi that I am converting gas to electric, I plan to run 8s only in this boat. I have this motor
https://www.ebay.com/itm/56112-B-Bru...Td40mNq2gw9bmA
KV: 780KV
Max power: 7350W
Poles number: 4
Max voltage (LiPo): 9S (780Kv)
Max Amps: 195A (780Kv)
No load current: 2.8A (780Kv)
Diameter: 56mm
Length: 112mm
Propeller will be octura x457.
Will a Swordfish X+ 200A ESC work with this setup? My goal is 50MPH.
Any suggestions appreciated.
KV: 780KV
Max power: 7350W
Poles number: 4
Diameter: 56mm
Length: 112mm
, unless you are confined to 8s by class rules I would use a higher voltage to reduce the amp draw at a given speed.
