Neu 1521 jet unit no cooling esc?
  • vvviivvv
    • 1148
    Hi,
    So I have a large 1,3m long mono im converting to direct drive, it was a geared belt drive...
    I really would like to not drill the hull if I can get away with it but...
    Would a 1521 1Y on 4s driving a 30 (maybe 35mm) jet unit require cooling?
    Which ESC should I go for? I have the as26's but they don't work very well with 4 pole hence my purchase of Lehner 2250's for my other boat and these are spare...
    I was thinking about longer run times using 10,000mah packs / side... maybe cooling would be needed?
    Uk SAW record holder
    A jet unit will be harder on things than a standard prop setups. A jet sees more of a constant load. So yes water cool ESC and motor. Just tap a fitting to the unit after the impeller and you’ll be good. You can also tap the exiting water into the unit before the impeller.
      Oh and most jet units like a lower rpm, say 20’ish thousand.
      • vvviivvv
        • 1148
        Hmm, how do these work with NEU motors?
        https://www.offshoreelectrics.com/pr...=ose-R-150C-v2
        I could always run them 3s with them ESC, my current ESC are 4-8s so for some reason I just figured in that range...
        And cooling... for some reason I have the urge to try and internal cooling system, little bit of a faff but could be cool... weight isn't a issue with this boat so thinking a nitro fuel tank, one of these and some ice cubes https://www.mhz-powerboats.com/shop/...ater-pump?c=81
        • vvviivvv
          • 1148
          correction, they are actually 28mm jet units...
          Would 2x 1521 1Y on 4s really need cooling spinning a 28mm plastic impeller...? hmm
            Have you got a pair of old Graupner drives there?
            • vvviivvv
              • 1148
              Yeah,
              anyone care to comment how the OSE esc's work with Neu motors, specifically the 1521 series?
