a single ESC to handle 3, 380 size motors?
  • Rumpelhardt
    • Mar 2017
    • 86
    Anyone make such a thing?
  • rearwheelin
    • 2101
    Probably not
    --Albert Einstein
    • rearwheelin
      • 2101
      Are 380’s brushed?
      --Albert Einstein
      • rearwheelin
        • 2101
        If there brushed then you could buy a 75amp pull switch and hook a servo to the switch
        --Albert Einstein
          If the motors are brushed then a single brushed ESC can run two, three or four brushed motors together assuming the amp rating is not exceeded. You would have to decide if you wanted to run the motors in series or parallel configuration.
          I an not aware of an ESC designed to run multiple BL motors but then I haven’t looked either. Some folks have had success running two BL motors from a single regular BL ESC, but many have not. ESC makers do not recommend it. As far as three BL motors is concerned, you would surely fail.
          • Rumpelhardt
            • Mar 2017
            • 86
            guess building some sort of gearbox to run 3 props off one bigger motor would make more sense. The bproblem is one of the props is reverse rotation so it gets a little more complicated.
              At your own risk. Possibly....
