Would like to run two identical motors on one ESC. Any problems?
One or two ESCs
Tags: None
Running two brushed motors on one ESC is no problem. Running two brushless motors on one ESC is problematic. The high-end ESC maker Schultze mentioned this in their ESC instructions, that it can be done by experienced bosters, but was not recommended. Like those above, my recommendation is not to do it.
Yes they do (two ESC's in one package $$$$), But if you have trouble with one, you have to replace both.Originally posted by Prodrvr View PostDoesn't Flier make a few esc's that run two motors on one unit?
I run two ESC's - it is a lot cheaper to replace just one if you have a problem.
Sometimes when you have a motor problem it will effect or take out your ESC. so now you have to replace one motor and one ESC.(NOT TWO)
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Agreed. Running two motors on one ESC can confuse the zero crossing detect circuits in the ESC, especially on corners. Even more problems under partial throttle...Originally posted by Fluid View PostRunning two brushed motors on one ESC is no problem. Running two brushless motors on one ESC is problematic. The high-end ESC maker Schultze mentioned this in their ESC instructions, that it can be done by experienced bosters, but was not recommended. Like those above, my recommendation is not to do it.
