zelos 36 problem
  • aboozel
    • Jun 2018
    • 1
    zelos 36 problem
    i have a zelos 36 that has not been used in about 6 months. i connected batteries and turned it on and the esc flash green and beep every second or so non stop. the motors or steering won't do anything.
    anyone have any ideas on where to start looking for the problem? thanks
  • MADRCER
    • Feb 2017
    • 765
    Do both ESC's flash green and beep or just one? If both do then it sounds like you need to rebind your radio to the receiver, if that don't fix it your receiver may be bad or you might have the esc plugged into the bind port on the receiver and not into the correct channel. If only one esc is flashing and beeping you probably have a motor wire not plugged in or that motor is bad.
