Swordfish data logger help
  • fred685
    • Mar 2013
    • 64
    I downloaded the software for the Swordfish ESc, but I keep getting a message saying to select a port. It lists 8 ports. I tried them all, and just keep getting error messages saying "wrong port". Can anybody help?
    Thanks,
    Fred
  • sweed_61
    • Oct 2017
    • 67
    What model esc do you ?
    • Old School
      • Aug 2017
      • 686
      Thanks,
      Fred
      Have you checked your Device Manager to see which port the software is on? You need to select that port.
      • fred685
        • Mar 2013
        • 64
        Yes, but my device manager doesn't show anything about com ports.
        • SlickZERO
          • Dec 2013
          • 138
          Did you get it figured out? What model Swordfish is it?
          Dumas Air Boat OS 25 nitro, Dumas Air Boat Brushless, Midwest Lobster Boat, AQ Lucas Oil Cat, Dumas Hot Shot IV Proboat outboard, Delta Force Cyber Storm 33
          • Crash
            • Oct 2015
            • 313
            Run the program as Administrator
            • SlickZERO
              • Dec 2013
              • 138
              I am on com port 4 and it recognizes the ESC and I can set parameters, log set up, gear and number of poles. I am running as administrator. When I click download log the blue bar advances and finally says
              C:\program files (x86)HiFei V6.0\2018-10-29.0.dat was not found.
              • SlickZERO
                • Dec 2013
                • 138
                I have one working but still no data retrieved.
                Any ideas how to get the data?
                • SlickZERO
                  • Dec 2013
                  • 138
                  Sorry, I thought I said. They are the Swordfish X+ 220A
                  • zooma
                    Local club FE racer
                    • May 2014
                    • 652
                    Hi Bret,
                    The software will not complete the download process without being run in Administrator mode. So put your mouse pointer on the shortcut, then left click and choose "run as administrator". It will complete and display the graphs.
                    Ron - The Villages, FL
                    • SlickZERO
                      • Dec 2013
                      • 138
                      I plug in the wire from the esc to the computer. I right click the desktop icon and select "run as administrator." A pop up says: "Do you want to allow this app from and unknown publisher make changes to your device?" I click "Yes". Then the software opens up. I click open device and in a couple seconds it displays the esc in the rectangular window on the bottom. From there I can change the parameter setting.
                      I click "Show the record". No esc is shown in the white rectangular box. I click "Open device". After a few seconds the white box still shows no esc. (It show it on the first screen as I said above). I click "Upload record data" anyway. A little blue bar advances from left to right. Sometimes quick and sometimes real slow. Then pops up
                      Note: Unless I run as administrator it won't let me set the parameters.
                      • trigger
                        • Sep 2013
                        • 853
                        on the logger configuration screen did you set the ESC to record at "X"per second intervals? I think I remember a few having no default set and thus nothing was recorded.
                        • SlickZERO
                          • Dec 2013
                          • 138
                          Yes, actually tried a couple different settings.
                          • Mrlocky
                            • Jan 2017
                            • 4
                            I am having issues with mine also. The esc does not seem to register at all. I dont have all the boxes on the screen either. I cannot click to go to parameter settings. To even get to the parameter settings i need to hit tab a few times and then enter. I have run the program as administrator also.
                            • EddieM41
                              • Aug 2018
                              • 195
                              I plug in the wire from the esc to the computer. I right click the desktop icon and select "run as administrator." A pop up says: "Do you want to allow this app from and unknown publisher make changes to your device?" I click "Yes". Then the software opens up. Then I click on the options across the top and nothing happens!!! This is very frustrating. I down loaded the software from the included disk and have been trying to make it work as Administrator. NOTHING...any more suggestions?
