Swordfish Pro2 240HV - Adding Cap Bank - Anti-Spark Wire
  • Pennstater
    • Sep 2015
    • 70
    I'm adding a cap bank to my ESC. The SF has a separate wire for the ant-spark lead right next to the main battery wire (see attached picture).
    When adding the cap bank, I assume that this anti-spark wire should also be soldered to the cap bank (if not, then I would suspect there would be a big spark when the battery connection is completed as the cap bank instantly charges).
    Is this correct?
    Thank you,
    Pennstater
    • 7651
    Just solder it to the bullet. It then will feed the caps. That is it’s job. It slowly feeds the caps to full instead of the caps just filling themselves with a big ‘SNAP’ when you connect battery. Also a good idea to move it over to the negative side. Easier on electronics this way(thanks Craig,lol).
