Need help finding a very small esc
    I’m looking for a small esc. I’m currently using a castle talon 35. I need something close to those dimensions and at least 25a. I do not want to use a pistix anymore and it has to be at least up to 4s. It needs to have a built in bec also. So to sum it up
    Size (around) 23mm wide x 49mm long. Height don’t matter
    Built in bec
    No pistix needed
    25+ amps
    At least up to 4s
    Maybe my talon can used without a pistix, if it can I’m not sure what I need to do. Any help would be appreciated. Go. Lol
  • jim82
    • Jan 2013
    • 1358
    What radio are you using? Spektrum I used an air ESC with the sub-trim throttle turned all the way back
      Originally posted by dmitry100
      Why not YEP 300? 150amp double stack... with pistix of course.
      Not sure if I should even reply, but are you being serious? I said a bery small esc. It’s going in something about the size of the esc your talking about. I need a micro esc.
        I’m using a spektrum. That’s all I need to do is turn the sub trim back? Will I still get 100% throttle?
        • denboy01
          • 62
          EnErG Pro Marine 60 Sbec Esc is a pretty small esc
            I’ve got a couple around Travis, I’ll go look now
              I have three but one is a brushed ESC one has no BEC and the third is a Traxxas Velineon 3m, not sure of amps on those
                I don’t think the traxxas one will do 4s?
                  Spektrums work great with all Castle air ESCs. Just use the right settings, no PiStix required. Haven’t used the latter in many years.
                  • Darin Jordan
                    • 9446
                    Make sure you set the Castle ESC for "Fixed Endpoints".
                    Darin E. Jordan - Renton, WA
                      • 4340
                      what's pistix?
                        what's pistix?
                        It’s a small device that allows you to use an air controller with a ground transmitter.
                        Thanks guys. I got it to work. So I just chopped a couple grams off and saved myself $25 for each time I need to use this.
                          Does anyone have a small talon esc they would part with? I wanna see if a 25a will hold up or even the 15a talon.
                            • 4340
                            There's a couple used 25A and 15A talons on eBay. This one has a best offer tag on it: https://www.ebay.com/itm/Castle-Crea...4AAOSwEzFZ47v6
                            • dmitry100
                              • Mar 2015
                              • 1264
                              kfxguy, unrelated but ... do you have a link to that one nice mini pump you got a while ago? Can't seem to find it in the forum
