Hobbyking aquastar/swordfish 240A
  • MrUnlimited
    • 94
    Guys,
    I purchased a Hobbyking aquastar/swordfish 240A for my FE 1/8 scale hydroplane. I'll be running on 8s lipo and a TP-Power 4070 5Y 910KV motor. Do I need to solder extra capacitors between the esc and the lipo's?
    Your advice please.
  • CraigP
    • May 2017
    • 1464
    Cap Bank is always recommended, close to the ESC as possible. I’ve never seen Hobbyking Aquastar associated with a Swordfish. That’s a Heifei product, I do believe..
    • Bp9145
      • Jan 2016
      • 1466
      Agreed, AquaStar(Turnigy) and Swordfish are two different and distinct ESCs. Also, the largest esc AquaStar makes is rated at 200A. I have both the SF 240A and the AQS 200A but yes, extra added cap banks are a plus to any esc and as Craig mentioned, solder closest to the ESC as possible is best.
      • MrUnlimited
        • 94
        This is the esc and it is the rebranded version of the Hifei: https://hobbyking.com/en_us/turnigy-...ooled-esc.html
        Hobbyking esc are made by brands Hifei and Skyrc.
        • Bp9145
          • Jan 2016
          • 1466
          I was thinking about this one. . .forgot about those
          https://hobbyking.com/en_us/turnigy-...rless-esc.html
          • Bp9145
            • Jan 2016
            • 1466
            I just checked that Aquastar 240A and yes I do believe it's the same as the SF240A. . .rebranded just like you said along with their other line like the T180 which the same as HW Seaking 180 with a slight difference for copyright reaaons. . .good to know. .thanks Rene
            • MrUnlimited
              • 94
              That one is made by Hobbywing and rebranded for Hobbyking
              • SD Eracer
                • Aug 2014
                • 262
                I believe the Aquastar 240 is just a rebadged Hifei Swordfish 240, it's pretty much identical specs, even the labels.
                Though Hobbyking has a 1 year warranty and will usually send you a new one even if you smoke it, just as long as you send them a picture as proof.
                • Old School
                  • Aug 2017
                  • 686
                  I am also interested in this ESC. I believe it to be a rebadged Swordfish 240 amp version 1 with no data logging. I would be using it on 6s with a 1280kv 56 series motor (twin set up) in a cat hull. Prop size is open ended at present. Several failure videos on You-tube dating back a couple of years with one recent video being unable to programme using the data link and computer.
                    OS, running 56-sized motor’s on 6S is actually a bit if a waste. A number of us tried this years ago but went back to 40-sided motors. Just more efficient, but the bigger motors have more mass and handle higher watts (volts) better. They will work on 6S, but are bigger and heavier than necessary.
                    • Old School
                      • Aug 2017
                      • 686
                      .......................................... They will work on 6S, but are bigger and heavier than necessary..
                      Would 8s be a better option then please?
