Huge difference between esc temps and motor temps
  • RuntheraceAMC
    • Sep 2016
    • 222
    Thanks for the chart
    • 785boats
      Wet Track Racing
      • 3423
      You are most welcome.
      But even better is one of these cell checkers.
      They give you voltages, and capacity remaining as a percentage. For both pack, and individual cells. Very handy little unit.
      http://www.offshoreelectrics.com/pro...emp-eossentry3
      Also try not to run at part throttle too much. That's is a quick way to burn out an ESC.
        • 4338
        fweasle.
        As you see on the chart, at 3.55v, you are seriously overdischarging your packs.
        Resting voltage after a run should be above 3.7v/cell.
        I'd raise your cutoff setting a bit to prolong the life of your packs.
        Thanks for the tip. I had to lower my LVC to 3.2V because it was tripping too early at 3.4V. The boat runs much better now and I'm in the process of fine tuning my run times on a 2 pack configuration. 3.55V was after 3.5min, next time out I'll stop at 3min until I start running with 4 batteries.
        • 785boats
          Wet Track Racing
          • 3423
          Are you sure it was tripping too early? Or was it tripping at the right time to leave the packs at over 3.7v/cell, ie 20% capacity remaining, when at rest?
          • boredom.is.me
            • Jun 2009
            • 626
            Forget the battery stuff for a minute. What about motor timing? If you were running at default on both, that may have something to do with it. Or would that only cause the motor to get hot?
            • RuntheraceAMC
              • Sep 2016
              • 222
              That's what was confusing to me. If it's timing, why isn't the motor hot. Even with the battery talk. Why is my esc 140-150 and the motor is at 90-100. If it was too much prop the motor would be hotter too
              • NativePaul
                Greased Weasel
                • 2770
                I don't know either of your ESCs but if the ETTI has default switching frequency that can cause much higher ESC temps and depending on the motor the motor may see no difference.
                • RuntheraceAMC
                  • Sep 2016
                  • 222
                  Are you saying that I constantly have to reprogram the timing. It's switching the timing on its own?
                    I believe Paul is reffering to the PWM. Do you recall modifying that step? I will have a look at one of my manuals when I am up and moving for the default setting.
                    Also, Do you have a cap bank on it as recommended by them? Always a good idea
                    • RuntheraceAMC
                      • Sep 2016
                      • 222
                      What is the PWM? Yes I have the extra bank of 5 caps. Total of 7 caps. image.jpg
                        Originally posted by RuntheraceAMC View Post
                        What is the PWM? Yes I have the extra bank of 5 caps. Total of 7 caps. [ATTACH=CONFIG]147509[/ATTACH]
                        Ok well I see a Y split in the water line, turf that. You may only be effectivivly cooling half the ESC. This is foremost! And while we are on that, water in to ESC then to motor. Is this how it is routed?
                        What size connectors and how much wire between batteries and ESC? Shorter is better. What I am looking at is the yellow connection block as a possible problem.
                        We will get to PWM
                        • RuntheraceAMC
                          • Sep 2016
                          • 222
                          I have separate water lines to motor. As for the Y's. I heard this many times but I can't just remove the cooling set up I have without tearing out everything. Next time I need to pull out everything I will be eliminating the Y's. But why we are on this subject: there are four cooling tubes on the esc, two on each side stacked vertically on top of each other. Each side has water from a separate pick up. I ran hose with 4mm inside diameter to the Y and then after the Y about 2" of hose (3mm inside diamete) to each cooling tube. This means minimal line after the Y with no kinks or severe bends. But even if flow is restricted to one they are stacked on top of each other so cooling is getting to at least one of them on each side. Plus the cooling plates on top are getting cooling to at least one.
                          I realize there is a better way to do this but it can't be horrible the way it is. It has to be getting some cooling.
                          I am using XT90 connectors for the batteries and 8mm bullets from the esc to the motor. I'll send some pics of the battery wires and my parrellel connector wires. All wires are 10 gauge
                          • RuntheraceAMC
                            • Sep 2016
                            • 222
                            • Mxkid261
                              • Jun 2015
                              • 734
                              I would ditch those XT90 connectors those have like 4.5mm bullets. 6.5 castle connectors would be a much better option
                                I am suspect of the XT90 plug as well as the cooling lines. I looked the XT's up and cant find the size of bullit. But the dimensions of the housing that I found would not allow big enough connectors for this. How can one expect to give enough power to warrent 8mm connectors at the motor when the battery connector is only 5mm? If it is even that. Neat connector though with the anti spark but you should have 8mm there too. Anti spark is not really necessary for 6s.
