Seaking 120a esc works but 180a doesn't? help!!!
  • RuntheraceAMC
    • Sep 2016
    • 222
    I have been upgrading my blackjack 24 into a psychotic monster and I believe my current ESC is holding me back. But when I switched to the Seaking 180a esc I had amazing immediate results followed by utter disappointment. Here is some background:
    I am running a leopard 3650 2750kv motor (I also have the 2450kv version and the 3660 2050kv) on an upgraded engine mount, using the blackjack 29 flex shaft and an upgraded strut. I am primarily running it on 4s & 5s (Pulse 5s 45c 4500mah) with 38-40mm 1.6 pitch props. In an effort to keep her cool, I also put in 3 additional thru-hull water pickups, so I am running 2 coolant lines to the motor and esc. I installed wider tubing and wider exhaust outlets.
    I expect that my motor is demanding more amps than my esc can deliver and that it could fail any day so I ordered the 180a Seaking. I also upgraded all my connections, series connecter and wiring to 10 gauge. The esc worked fine initially on 4s and I could tell there was more burst from the same batteries. After running 4s for a few mins I switched to 5s. The first pass was AMAZING! I could not believe the additional power the motor put out, but before I could even do my second pass the esc cut to half power. I brought the boat in and checked temps. The esc and motor were barely warm. I checked voltages and they were close to 4 volts. My lvc was set at 3.4
    I had the esc reprogramed just in case and I checked the timing and lvc to make sure they were set right. Second try, same thing. Tried a different battery (5s 25c 4200 mah), same thing 1 pass and it cut. Went back to 4s and that didn’t work, neither did 3s. I put my Seaking 120a back in the boat and it has been running fine for the last several times out. Maybe I should be content there but with the additional power I saw out of the 180a I want to keep trying. I sent the 180a back and Steven tested it running 100amps for 10 seconds with no issue.
    What do you all think defective esc? Try a different brand? I expect some comments that my KV is too high but I tried to see if the esc would work on the 2050kv and 2450kv, no dice. Any help would be appreciated!
  • Mxkid261
    • Jun 2015
    • 734
    Try and turn off LVC on the 180a and see what it does I have 4 of them and they can be picky depending on what batteries are hooked to it
    • RuntheraceAMC
      • Sep 2016
      • 222
      After trial and error I returned the 180a. If it happens on the next one I could try that. I guess I was looking for suggestions on an alternative but that esc should have been a good choice.
      I am looking at the OSE Raider 150, Turn 180, Swordfish 220a and any other suggested esc's. Keep in mind my current set up listed in my original post but I am also considering changing motors to the leopard 4074 1800kv. Also thinking about a TP 3640 1935KV.
      • Mxkid261
        • Jun 2015
        • 734
        Raider 150 would probably be the most practical option
        • RuntheraceAMC
          • Sep 2016
          • 222
          Thank you! Any other thoughts appreciated.
          • martin
            • 2881
            Perfectly normal on these esc, this is a well known problem. They have an over sensitive lvc, most disable the lvc & time their runs. Low c batteries also don't help with this problem but sometimes high c batteries also has the lvc cut in.
            • RuntheraceAMC
              • Sep 2016
              • 222
              That's good to know. When Steven said that could to be the issue I was scratching my head. But to hear it is a well known problem sets me at ease. I just ordered the OSE raider 150. I'm sure that will do me just fine. Also ordered a 5s battery that's 70-140c and the leopard 4074 1800kv. I think that will be on the edge of the raider 150a capabilities. What do you guys think?
              I also think this BJ 24 is gonna be nuts!
              • RuntheraceAMC
                • Sep 2016
                • 222
                I went with the Raider 150 and am very pleased! I'm running a Leo 4074 1800kv on 6s and it comes in cool every time. Boat is a freaking rocket too. Thanks for the advice.
                • Mxkid261
                  • Jun 2015
                  • 734
                  Good to hear. I am planning on picking one of them up eventually.
