What esc to use
  • langevn
    • Mar 2015
    • 214
    What esc to use
    Hi like to know what is the recommended speed control for castle 1515 1y 2200 kv and also the timing
    Sent from my Nexus 4 using Tapatalk
    That depends on what it's going in and how many cells. You can get away with a Seaking 120 set at 15 degrees timing if your not pushing it real hard and running on 6s. More details will net a better answer....
    • langevn
      • Mar 2015
      • 214
      I am using 2 x 2s 7.5 v 6800mah and 6200mha
        Ok. I give up.
        • langevn
          • Mar 2015
          • 214
          the boat is an insane fe 30 and goin to get m445 prop with those batteries from posting 3
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5195
            You may have an issue...are those batteries from the same manufacturer? and also not advisable to run batteries with different mah outputs in series.
            Douggie
            • langevn
              • Mar 2015
              • 214
              i have st of them 2 the same 2x 6800 and 2 6200
              • rayzerdesigns
                • Dec 2013
                • 1228
                just get a seaking 180 you will be safe
                • properchopper
                  rcgoatbuild@snotmail.com
                  • 7708
                  We designed the FE30 as a P-Class or P-Ltd Class heat racer (4S2P or 2S1P x 2 or 4S1p)
                  If you're using the 1515 1Y P-Class motor you can't go wrong with the T-180 (with a little mod to the waterline direction) or lately I've been building them with the Swordfish 220A.
                  Best battery setup for full P is 4S2P 4000mah [e.g. 2 X 4S 4000mah packs]. Just DO IT - don't use the packs you're mentioning. With 4S2P you'll have plenty of headroom and enough runtime for a mill + 6 laps on a 1/6 mile course (which is a bit over three minutes at P speeds if you're just sport running) AND the weight will keep the boat planted.
                  Y winds can , if not heavily loaded, use high e.g. +15 degree timing or anything close.
                  Here's a bunch of FE30's with T-180's and near the last pages 220A Swordfish ESC's
                  http://forums.offshoreelectrics.com/...at-RCBOATBUILD
                  • langevn
                    • Mar 2015
                    • 214
                    Hi I only have these I just got them not long ago and budjet iks limited I will have to use those batt are AGA power 2s1p 7.4 6200 mah 50 c and the other set are AGA power 2s2p 6800 mah 70c and I got them before Xmas I will have to try these until can afford other one and thank you for all the reply
                    • properchopper
                      • 7708
                      Keep in mind that both the T-180 and the 220A Swordy have been known to have rather overprotective LVC's SO you'll likely be encountering this issue using batteries that have less capacity that the fairly amp hungry 1515 1Y like to feast on. Starting with a slightly smaller prop like a de-tounged X442 will consume a little less power but still give plenty of speed
                      • langevn
                        • Mar 2015
                        • 214
                        I don usually have the LCV activated I use external 6.6v life batt for my cervo
                        • langevn
                          • Mar 2015
                          • 214
                          And also I race in the D1 impba so some rule to apply with some voltage and amp
                          • TRUCKPULL
                            • 3293
                            As far as I know D1 (Northern Lights) have NO limits on ESC's
                            There are limits on Max volts, and Max mMP's (in battery capacity) allowed on board.
                            Also your length limits per class.
                            Larry
                              Go smaller on prop like propchopper said. A detonged 442, maybe m440 3 blade thinned.
