Is auto ESC timing proper for delta wind motor?
  • zooma
    Local club FE racer
    • May 2014
    • 653
    I am setting up a Q mono with a Leopard 4092 1480kv 3.5D wind motor, and Swordfish 220 Pro+ ESC on 6 cells. This is my first delta wind motor. My research here and elsewhere shows that delta wind motors like low timing as compared to wye wind. On my wye winds, I use auto timing if the ESC has that setting, and 5-10 deg if fixed only. I expect to use auto timing on the delta wind motor, unless advised not to. I am looking for practical experience from forum members. Thanks.
    Ron - The Villages, FL
  • Jamey
    • Apr 2015
    • 199
    Zooma, FWIW I run 3.75 degrees in my Seaking with that motor. Runs well but I need to do further testing at other settings to know anymore.
    • RaceMechaniX
      • 3024
      If you have fixed timing try 5 Deg or less first. Make a short run and check temps. You can try upping the timing, but you will likely only get more heat and no more performance.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
      • 785boats
        Wet Track Racing
        • 3423
        I always use the Auto setting on the Swordfish ESCs for both Star or Delta motors.They always seem to run cooler than when you try to select a setting.
        • zooma
          Local club FE racer
          • May 2014
          • 653
          ok, still planning to use auto
            Auto works the best for me with sf escs. No matter if they are delta or wye.
              I'm going to try this in one boat since any specific timing settings will not let me get 6+ laps out of it. If that doesn't work, the motor may be on the way out.
              • zooma
                Local club FE racer
                • May 2014
                • 653
                Thanks. I was hoping to here that.
