MGM program problems, need help
  • RandyatBBY
    • 3915
    I received two MGM TTM 28026-3S yesterday. I was cautious about hooking them up in the boat with out reading the instructions manual, because I was tired. I waited untill this morning when I was fresh to start reading the manual. after t.5 hours of reading I hooked the controller up to the computer and opened the program. The instructions said to up date and install new firmware. I did that everything was working fine to this point. I went to settings and selected 8 cells and a few other settings I can not remember right now. I proceeded to hook up the second controller and go there the same process. Once all that was done I installed the controllers in the boat and tried to run the system. It did not make any tunes aand did not work at all. I went back to the controller and It will not light up the text showing connection and can not get the program to recognize the ECS. I need help thanks in advance.
    While I am at my shop I do not have internet so be patience with me I will read it when I an at home.
    Randy
    BBY Racing
  • RandyatBBY
    • 3915
    I just hooked up the ESC to the Computer and this time it worked. I reset the default on both controllers we will see if it works now.
    Randy
    BBY Racing
    • RandyatBBY
      • 3915
      Well I tool the controllers back to the shop and hooked them up and tested them, still no work. Any ideas?
      Randy
      BBY Racing
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        Is the computer installing the USBCOM4? what version of windows are on both computers? are you using a USB extender on any computer?
        • RandyatBBY
          • 3915
          Not sure on the USBCOMP number. Windows XP, no extender
          Randy
          BBY Racing
          • oscarel
            • Dec 2009
            • 2135
            What the lights on the controller doing?
            • StevenBryant
              • Nov 2012
              • 359
              This esc is for upto 6s only not 8s, this is your problem
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                Ofcause lol didn't even look at that, yes that would be the problem
                • RandyatBBY
                  • 3915
                  Ok you guys are right. I do not know why I did not see that. what would be the right ESC for me? It is the Central RC Marine build I did twins. I might have hurt the ESC putting them on 8S?
                  http://forums.offshoreelectrics.com/...arine-53-build
                  Randy
                  BBY Racing
                  • Namba328
                    Factory Team Pilot SPP
                    • Jul 2011
                    • 1149
                    Randy I believe these esc's had a over voltage protection that shuts themselves off if you plug in a battery outside of there range. I may be wrong.
                    Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
                    Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
                    • RandyatBBY
                      • 3915
                      Ya they do Tommy, We are gona run the boat on 4S for a while and see how it goes.
                      Randy
                      BBY Racing
                      • 427srule
                        Racer
                        • 164
                        Randy,
                        These controllers do have over voltage protection. You should be ok
                        For your 8s set up, MGM 25063-3(250 amp) or 40063-3(400 amp)
                        Mike
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          For 8s the 25035 X3 will do just fine :) they are also the same size as what you got already
                          • RandyatBBY
                            • 3915
                            Thanks Nate I will check it out, the factory is closed till middle of the month. Rick is going to have a little fun the way it is for now.
                            Randy
                            BBY Racing
