Esc
  • blizard05
    • Jun 2007
    • 585
    Esc
    Do you rely need a water cooled esc for a boat ?
    America home of the free, thanks to the brave [/url]
    That depends on a whole bunch of things.....
    • blizard05
      • Jun 2007
      • 585
      Closed in boat running 2s 5000 30c
        Hey great, that's all the info we need to answer your question (sarcasm). Seriously, we can't read your mind and I'm not going to pry the info out of you. If you want a question answered, it's good practice to give specifics. I guess that's why no one else has posted. Not sure why I'm wasting my time posting either.
        • blizard05
          • Jun 2007
          • 585
          Thanks for nothing IT was a general question
            I try to help whoever I can. But with a lack of info, how can I help? How could you expect an answer. In short the answer is yes, you need water cooling. There's your general answer for a general question. Some people may argue that. There's some situations where you might be able to get away with no cooling. I use it on everything I build. It helps greatly. If your only running for a few seconds and then let it cool, then you may not have to use it. On little toy boats, you really don't need it. It's there more for novelty. Example, a blackjack 9. If you e ever seen the cooling they attempted its probably more for looks than anything. Now if you have a specific setup that you want some advice on if it's a good idea to use cooling, I'll be glad to offer my opinion.
              • 7512
              No...as long as your setup draws minimal amps you will be fine without it.
              No...as long as you keep your runs short if the current draw is high.
              Some very generic answers to a very generic question.
              Some folks use fan cooled ESC's with good results as well.
              • Doug Smock
                • 5359
                Dang Travis if you're running out of patients perhaps you should take a little break.
                MODEL BOAT RACER
                IMPBA President
                IMPBA 19887L CD
                NAMBA 1169
                  I apologize. I sent you a pm
                  • Heath M
                    • Mar 2008
                    • 865
                    I run an Aquacraft 45 amp esc on 4s without water cooling, it does however have a 6v fan attached to it.
                    Brisbane,QLD, Aussie
                    • blizard05
                      • Jun 2007
                      • 585
                      have a M M,Tacon 40 74, 2200 kv looking at ESC 160-200 amp So yes I do need water cooling. I am working with a low budget. New to FE, been running gas boats for over 20 yrs
                        If your running roundy round, I'd recommend water cooling. If your making short speed passes, you could get away without it especially on low amp setups. On high amp setups I'd definitely recommend it. I had a boat one time that the cooling system was plugged (I didn't know) and it lived for several passes and is still going. But I think I was just lucky. The way I noticed it was starting to run hot is when I got some water on me that came out the cooling exit and it was very warm. Not sure how water even got in there, it may have not been completely plugged but it wasn't spitting water out as it came by.
