MGM 28026-3 Pro WR
  • depeche_mode
    • 144
    MGM 28026-3 Pro WR
    Hi MGM owners
    A little help please
    My 1. ESC as of this morning Will not connect to computer (any computer in the house)
    2. Does not make motor spin
    3. Servo moves, no lights on side of unit
    I can not believe this expensive ESC failed please tell me how to reset it??
    P.s. the water tubes (well 2 of them) were loose and pulled out when I was fitting the water tubing
    Not what i expected for that much $$$
    Thats life
    wow
    For sale lol 4 day old ESC
    This isn't good. These things are supposed to be pretty much the best you can buy. Contact the seller or more about it.
    • oscarel
      • Dec 2009
      • 2135
      Did you use it with the Lehner 1940/7 on 6s? If so, what prop did you use?
      • depeche_mode
        • 144
        No LP 4082 2000kv 4s
        • oscarel
          • Dec 2009
          • 2135
          See if it will let you update the software on the esc. I had one that acted like this and this is what MGM had me try and it worked. I don't have the procedure with me, can have it later tonight.
          • depeche_mode
            • 144
            Thank you. Please tell me when you can. I will try anything not to send it back to the EU.
            • oscarel
              • Dec 2009
              • 2135
              Unfortunately I don't have the instructions, they're on the old rocketcityracing site. Going from memory, open controller software on pc and hook up usb module, hook up the esc and turn on power. Go to the system tab, firmware update should be available. Click on it, turn off then on the esc. It should attempt to upgrade firmware. If this doesn't work then you'll have to contact MGM.
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1837
                or try... https://www.youtube.com/watch?v=Tgs1zOIJQ0k for the firmware. If its not connecting to the computer, check if one of the tiny tiny pins are bent
                • depeche_mode
                  • 144
                  @nata2run Thank you
                  Pins ok will not connect to CPU
                  Download error
                  WUx18 Socket Connection failed (10091:SSL/TLS support is not Compiled
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1837
                    Any lights flashing on the controller or on the USB card?
                    • jj2003
                      HIGH VOLTAGE ADDICT!
                      • May 2011
                      • 1501
                      This is a handshake error (communications) between the PC and the Controller. Try to re-install the software or download the newest version directly from MGM's website. The installation disc could have a corrupt file or more on it. Once connected you can do a Firmware update through the software. Make sure you have the correct version for your controller. There are currently 3 different software programs.
                      "If guns cause crime, all of mine are defective"
                      45"Speedfreek
                      , Fightercat #068 ​, MyYoutube Vids
                      • depeche_mode
                        • 144
                        Thank you
                        @nata2run UsBCOM5 board is blinking green light , controller no lights.
                        @jj2003 done, using v3.0.5, software sees USBCOM but not controller
                        • nata2run
                          customcfparts.com
                          • Nov 2011
                          • 1837
                          Hmm, so one more question... when you plug in the lipo, any lights sound? you did mention no light, but sound at least?
                          • depeche_mode
                            • 144
                            Quite no sound at all...
                            • depeche_mode
                              • 144
