ESC timing ?
  • Andris Golts
    • 508
    ESC timing ?
    Hi all running a UL-1 2030 kv 6 pole with ETTI 150 amp esc in my outrigger last summer just checked the timing on esc and found it set at 2 degree advance which is for 2-4 pole motors .Would running a 6 pole motor in a 2 pole setting cause damage to motor or esc? Regards Andris Golts.
    I run timing at around 10 degrees some go up to 15. Low timing on these motors may not be the best or most efficient.
    • TRUCKPULL
      • 3293
      I run my UL-1 2030 kv 6 pole at 12 degrees
      The stock esc that came with the UL1 was set at 12 Degrees also.
      Larry
      • Andris Golts
        • 508
        Thanks Ray And Larry for the information. Regards Andris.
