I'm looking at getting one of these. I cannot find measurements I need. If you could help me out, I'd appreciate it. Before I spend this kind of money on a controller, I'd like to make sure it fits ya know! Thanks in advance!
Does anyone have an mgm 25063-3 esc?
It will depend on which variation you get. i.e. one has the caps vertical and the other has them horizontal.
For the vertical caps, the measurements are 63mm wide, 96mm long and 61.21mm tall including the caps.
See page 32 of the attached manual from MGM.
en-manual-x-series-250-400-b15-040811-a1 pg 32-33.pdfTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Originally posted by RaceMechaniX View PostIt will depend on which variation you get. i.e. one has the caps vertical and the other has them horizontal.
[ATTACH]128714[/ATTACH]
thanks for the reply. the measurement i need specifically is from the botton (as if sitting on the table) to the top side of the circuit board (where the caps are soldered) and then from the bottom to the side of the caps (laying down). Imagine as if i were going to slide the cap portion of the esc under the deck lip where the hatch sits....thats why i need these measurements. I'm going to mount it where you dont see the cap end of the esc.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
It is 26.21mm from the bottom to the top of the PCB as you have described. The caps are 12mm in diameter so roughly 32.21mm overall plus some clearance to get under your deck.
TGTyler Garrard
Thanks Tyler! Just what I needed. It will fit so I'll be getting one. Thx!Originally posted by RaceMechaniX View PostIt is 26.21mm from the bottom to the top of the PCB as you have described. The caps are 12mm in diameter so roughly 32.21mm overall plus some clearance to get under your deck.
TG32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
