Is there any reason you can't run two motors off one ESC, for instance a 240amp Swordfish pro plus with two 4060 tp 1860kv on 8s this combo will be in a Drag boat. So no long runs just short bursts.
1 ESC 2 Motors
Tags: None
if not its going to be an expensive lesson.....lolOriginally posted by flraptor07 View PostI think I'm gonna hook it up on the bench and see how it works, as long as both motors react the same it should work.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I've seen it done on on Youtube with a T180 and a pair of T600 motors if I'm not mistaken. Does work to a degree but, one motor may start before the other and one might turn the opposite way on occasion too.
It works, a member here tested with up to 4 motors several years back and posted it, vids are on youtube. Amp draw will be your main concernNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Here's one of his vids:
Here's one of his that is more technical, hooked up to a computer and has the motors under load he tests thrust etc.......
ReddyWatts fleet photo
