CC Hydra 240 stick position
  • PJBJ
    • Feb 2014
    • 26
    I have a Futaba stick transmitter and a CC hydra Ice 240 ESC.
    As it is set up now, I am only able to use the throttle stick from the middle position to the top.
    I have no reverse so the lower part of the stick movenment is not in use.
    I have heard that with this ESC there is no way around this.
    I have not been able to find any info on this, and want to check if it is possible to use the entire stick movement for forward direction (neutral at the bottom).
    Thanks
  • RaceMechaniX
    • 3024
    If you have a stick radio with EPA (End Point Adjustment) you can try turning down the reverse or brake side end point. This should give you more range from the stick.
    If you have a 3VCS, the radio probably also has a "Throttle Mod" setting which will allow you to change the bias from 50/50 to 70/30 so you have more usable throttle range.
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • PJBJ
      • Feb 2014
      • 26
      Thanks TG
      I will try with turning down the reverse side EPA setting.
      I do not have a 3VCS
