Aquacraft UL-1 Superior ESC Wire Length Question
  • Jonny15678
    • Jan 2015
    • 45
    Hi guys I recently got my new RC Boat and Had to change the wires around a bit for everything to fit properly especially the Lipos. As you can see the ESC wires arnt too long there fore they are kinda pulling the ESC off the velcro it held on by. Is there anything I can add or adjust to keep the ESC held down a bit better?
    John
  • trigger
    • Sep 2013
    • 853
    Rotate the esc 180 degrees.
    • Jonny15678
      • Jan 2015
      • 45
      If I do that my lipo's plugs wont reach the ESC connectors
      • Jonny15678
        • Jan 2015
        • 45
        [QUOTE=Jonny15678;611449]If I do that my lipo's plugs wont reach the ESC connectors
        I'll try it and see how it works
          • 5660
          Mount your lipos with the wires towards the motor is another way. See if that works, make sure no wires will get caught with the collet.
          • Jonny15678
            • Jan 2015
            • 45
            Well I did it and it looks alot better than before way less tension on the wires. Also is it bad to bend the motor wires I've bent them around a couple times when I got the boat trying to rewire it. 100_1680.jpg100_1679.jpg100_1677.jpg100_1676.jpg100_1675.jpg
            • Jonny15678
              • Jan 2015
              • 45
              Is there Something else I can use to hold the receiver, ESC and Lipos down besides the stock velcro? The velcro lets the Lipos move too much.
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                try some heavier duty velcro. the batteries don't need to be solid as a rock in there. as long as they are stuck well its fine.
                • Jonny15678
                  • Jan 2015
                  • 45
                  I'll try that Thanks :)
                    • 5660
                    I get INDUSTRIAL STRENGTH Velcro, it is not the thin ones you get from the boat, but you need to use that with care, I cracked a hull once tearing the batteries off the velcro. I put only a short piece( 2"or so) on the battery . I use credit cards to separate them rather than just yanking the batterty off the velcro.
                    Picture looks good, but YOU MUST FIND A WAY TO CLEAR THE WIRES FROM TOUCHING THE COLLET!
                      • 5660
                      Whoops, Didn't see the post, you have been pointed in the right direction!
                      • Jonny15678
                        • Jan 2015
                        • 45
                        http://www.walmart.com/ip/Velcro-Ind...2-x-4/17338208
                        What is the collet?
                          • 5660
                          The black thing on the motor shaft that grabs the cable!
                          • Jonny15678
                            • Jan 2015
                            • 45
                            Oh okay
